So I bought an Ebay turbo kit for Wilson
Old 03-30-2017, 10:17 PM
  #211
Noahs944
Noahs944's Avatar
Spencer totally came through for me!!
I had no idea the 951 set up was this intricate.
MUCHO GRACIAS!!!
Ahead of sched brotha!
This is exactly what Wilson needs & deserves.
And since it's my lucky day... the Greddy EBC came in from JAPAN. That's a long ways a way mister.
Old 03-30-2017, 11:50 PM
  #212
V2Rocket
Rainman
V2Rocket's Avatar
get'r'dun..
Old 03-31-2017, 11:10 PM
  #213
Noahs944
Noahs944's Avatar
Suggestions for online spec reference for assembly of 951 engines?
Torque values, clearances... factory manual type stuff, anyone?
Old 04-01-2017, 12:41 AM
  #214
Noahs944
Noahs944's Avatar
SoI was wrong in an earlier post where I mentioned my oem turbo pistons didn't have a "series" stamp. Although faint, they are fortunately "1" series just like my n/a pistons & block.
But I'm check compatibility & found the rings are the same gap.
Why are the turbo rings beveled on the inside edge?
Are the n/a rings appropriate for boost?
Do the cheap goetz rings work on boost?
Old 04-01-2017, 04:15 AM
  #215
odonnell
odonnell's Avatar
The 951 rings are different. NA rings can probably take boost fine, but the unknown here is long term reliability. I measured some goetze rings and their end gap was sometimes almost double the spec.
Old 04-01-2017, 10:37 AM
  #216
V2Rocket
Rainman
V2Rocket's Avatar
http://www.9ss1.dk/porsche944/garage/manuals/vol1.pdf
Old 04-01-2017, 11:58 AM
  #217
Noahs944
Noahs944's Avatar
Found this to be the best oem ring information source:
http://federalmogul.com.tr/pdf/brosurler/CATGT1001.pdf
Old 04-01-2017, 01:23 PM
  #218
Voith
Voith's Avatar
Maybe goetze is better for porsches but if you ever rebuild bmw engine, don't use goetze -ever.
Old 04-01-2017, 07:07 PM
  #219
Noahs944
Noahs944's Avatar
Okay so I learned about 2.5 944 rings last night whilst tipsy on beer & fatigue... & this morning on the internet. The above link I posted this morning has pretty much all the information a person needs to know on Geotze rings. What came in your Porsche? What did the other Porsches have?
It also lists the material and shape of each rings, so you can tell if the rings have been replaced. Are the rings the correct orientation? I eventually figured out that the guy who sold me the 951 pistons put the secondary rings where the top rings should be.
As you can see, I did previously buy a complete set of rings for 100mm 2.5 pistons. But at the time I was looking to build a Kung Fu 16 valve 2.5 n/a engine. These new rings seem scrawny for the 951 application, and as Michael says... who knows how long they'd be good for. I do know this: they aren't going in W.I.L.S.O.N.
Old 04-01-2017, 07:09 PM
  #220
Noahs944
Noahs944's Avatar
I went through the trouble of including this information for anyone else who has a 944 S up to the turbo.
Notice there are engine build dates.
By using these charts I was able to check the build date & reference the materials and shape of the piston rings.
I learned that the 944 S & the 87 up 944 came with the same piston rings as the TURBO. I love the late 944.
I will be reusing and re-gapping (if required) the rings that came out of WIlson. I have complete confidence in the rings and they will go back into the same cylinders they came out of. Only on turbo pistons this time.
Old 04-01-2017, 07:23 PM
  #221
Noahs944
Noahs944's Avatar
Got my 951 intake in the mail today & dropped by my old work & had my friend weld the anti slosh flap in the pan.
Old 04-01-2017, 08:26 PM
  #222
ealoken
ealoken's Avatar
Nice
Old 04-01-2017, 10:24 PM
  #223
Noahs944
Noahs944's Avatar
Thank you mate!
I know it's ideal to replace rings, but last years compression test numbers were 150-165psi range, felt peppy & didn't burn excessive oil. The money is better spent on clutch or brake upgrade & in say 150,000 kms I will do a complete rebuild, main bearings & everything.
-Checked ring gap for every Porsche ring. .020-.025" for top 2 rings and .030-.032" for bottom ring.
-Cyl bores look good & no finger nails catch.
-Due to being forged pistons from a timing belt mis-hap, there were sharp edges where the valves hit. Cleaned up with a die grinder (very low speed) & stone to help prevent detonation under BOOST also cleaned carbon off sides & top with wire wheel.
-Verified piston oiling holes were clean with drill bit.
Old 04-01-2017, 10:57 PM
  #224
V2Rocket
Rainman
V2Rocket's Avatar
now would be the time to fly-cut the pistons to make them non-interference in the event of belt failure...
Double check your ring gap:
WSM says:
ring 1: 0.20-0.45mm
ring 2: 0.20-0.45mm
ring 3: 0.38-1.40mm
0.45mm is 0.0177"
Old 04-01-2017, 11:51 PM
  #225
Noahs944
Noahs944's Avatar
Lemme guess... you knew that off the top of your head. LOL.
I noticed in following various threads that each manufacturer of rings specs different gaps.
In my searching today and last night I found 2 favorite threads.
One is where there was Goetze ring confusion... finally settled by Pelican Parts stating and proving that Goetze now provides only 1 944 100mm ringset. Which is the 944 turbo ringset (I verified that the part number matched the original p/n in the catalogue pages above.... so, overbuilt but fully functional for low hp n/a applications).
Gap-wise, Mike Lyndsay became my mentor in this thread.... so I just kinda based what is loosely acceptable specs for the Goetze here: https://rennlist.com/forums/944-turb...-ring-gap.html
Quick Reply: So I bought an Ebay turbo kit for Wilson
