Timing Belt tensioner question
Installed new timing belt, when I set the tension and then torque the nut to the recommended 33 ft-lbs (per clarks-garage) I can still move the tensioner.
It doesn't seem to move on it's own but if i put the 27mm wrench on it I can still move it. Again it doesnt seem to just flop around it just isnt 100% locked down like I would expect once torqued. I've marked it so i can watch for movement.
Is this normal/ acceptable? the last thing i want to do it over torque it and end up trying to fish stud out of the block.
It could be that your nut is damaged and creating too much friction, so your torque wrench sees 33 ftlb before the nut is actually on enough. Maybe try a new locknut.
About a year ago, Dougs951S and I were doing belts and this happened:
https://rennlist.com/forums/924-931-...ner-studs.html
Tl;dr the stud was spinning in the block.
Thanks for the replies guys,
I marked the stud, nut, and tensioner so i can easlly keep an eye out for movement. I spun the motor over several times by hand and nothing moved. I went ahead and fired it up last night and still no movement. I've yet to take it for a drive waiting on the weather to clear up.
I'm cautiously optimistic that I'm being paranoid, it does take the wrench and effort to get it to move.
Update - should not have driven it.....
I drove it to work a couple of days this week probably well under 100 miles total. This morning I was out and I thought I heard a faint rattle it seemed to go away with RPMs. Went home pulled it in the garage and popped the hood to a timimg belt flopping all over the place.
My Christmas Miracle is that somehow it didn't jump time.
Moral of the story if you think it wrong and have to ask the interwebs if it's ok.... it's probably wrong.
