944 OBD Project (On-Board Diagnostics)
#616
Virtual Guages
Hi everyone!
I just pushed FocusOBD v1.2.253 to the website, this build has a new virtual gauges tab! Only engine RPM in implement at the moment, but I will add more gauges in short order. This is a feature I have been wanting since the beginning, and I am very excited it is now coming together. I could have used a number of off-the-shelf libraries, but I wanted the style to resemble Porsche analog gauges. It took a while to learn how to build gauges from scratch in software, but I think the result was worth it. Once I have enough gauges designed, I will allow you guys to decide which ones are displayed, there size and position. There will also be a feature to "swipe" to different customizable gauge sets in real time. Try it out and let me know what you think...
http://www.ftech9.com/
The following 4 users liked this post by Ftech9:
#617
Hi everyone!
The following 5 users liked this post by Ftech9:
Rick GT3 (11-25-2023),
riouxc (11-23-2023),
spencang (11-23-2023),
T&T Racing (11-22-2023),
Tom Pultz (11-22-2023)
#619
What would be awesome is a digital FQS. So you could change the setting via bluetooth. It would be nice to test different settings without tearing into the passengers footwell every time. Perhaps the obd board could bypass the physical switch to allow this?
#620
The original virtual FQS concept was to allow the mechanical or virtual setting to override each other. For example, if you adjust the virtual FQS, it will automatically override the mechanical FQS setting and vice-versa. Virtual adjustment could be done form the FocusOBD software or from a rocker switch connected to the OBD+ module. I was thinking about using a factory rocker switch installed in an unused location on the center console. I could even take this a step Furter and create a small 7 segment display to show the current setting, possibly even make it fit in a second unused switch location.
Unfortunately, implementing Bluetooth support on the iOS or Android platform is not going to happen for a at least a year or two.
Let me know if you have any input on this feature, I would very much like to know what you have in mind.
- Joe
#621
FocusOBD Update
Hi Everyone,
I just pushed FocusOBD v1.4.358 to the website, it has a new virtual coolant temperature gauge. You can select Fahrenheit or Celsius from the "settings" tab and the gauge will update automatically.
#622
Hey Joe, I sent a couple PMs to you regarding MAF beta testing but I’m not sure if they’re going through, I had a couple issues with emails not sending as well.
On a related note, I was able to purchase one of your DMEs with OBD! I just installed it in my car this week and so far it’s been excellent. The only issue I’m having is that there’s been a couple times when dead cold where it takes 2 key turns for the car to fire, an issue I suspect is a fault of my aging AFM. I’m one of those people a MAF conversion makes a lot of sense for.
If my messages went through, you’ll have some more context and you can reach me via my number I’ve left for you in there!
#623
Sorry I missed you email/post! For your cold start issue, feel free to record a data log and email it to me at joe@ftech9.com, I am happy to take a look and let you know if I see anything out of place.
Regards,
Joe Baumbach
#624
FocusOBD Update
Hi Everyone!
A new FocusOBD update (v1.6.367) is now available to download on the website, this time I added new virtual Intake Air Temperature guage.
One diagnostic check I allays do is if the car has been sitting over night, the IAT and ECT temperatures should more or less match. If this is not the case, then you likely have an issue and the sensor that is close to the current ambient temperature will be the good one.
#625
DME Sport+
Joe,
My DME Sport+ is installed and working well too.
One issue I experienced was dieseling after key off one one occasion. I sent you the data log so lmk if there is anything of note.
#626
The scales on the IAT and ECT seem a bit wierd. For instance, one hashmark between 180 and 220 F apparently is 20 deg, but one hashmark between 220 and 250 is 15 deg. Also the scale on the IAT is an odd 19 deg between hashmarks.
#627
VDO had many different ECT gauges over the years, I picked one I liked and modeled mine after it. For the IAT gauge, there is no VDO version for this, so I just came up with a temperature range I felt was useful and implemented it. To be honest, I never considered anyone would have an issue with the tick marks as gauges are generally used for "quick glance" evaluation and the exact value is displayed digitally. If you have suggestions for the ranges and/or tick marks, I am more than happy consider implement it.
Joe
#628
Hey Joe,
Installed OBD Sport + DME and it was a simple and painless install. I purchased the Lindsey MAF kit and am working on its install. Is there a wiring schematic for the 4 wire plug for the WBO2 to connect to the WBO2 harness (Autometer) ?
thanks.
thanks.
#629
Black -> Ground
Yellow -> +12V (Switched Ignition Voltage)
Orange -> Analog signal input
Brown -> Analog signal ground
- Joe
#630
Autometer wbo2 schematic lists a "signal input (+)" - would that correspond to the orange analog signal input?
and "signal input (-) correspond to brown analog signal ground ?
also does the wbo2 connect on ecu just perform diagnostic/data logging functions or does it actually perform engine management functions?
