half-price Koni strut conversion, 87-88 944 Turbo
Two sets available for immediate delivery.
I have two sets of mismatched 87-88 944 Turbo struts that need to make room for complete sets. Per set, one strut is from the 87-88 951 while the other is from the 86 951.
The offer is for 1/2 price normal conversion ($55/pr v. $110/pr) plus the cost of the 8641-1414S and normal s/h. Can be modified for use of adjustable ride height kit (lower perch removal, +$25/pr).
The differences are slight, but noticeable. They will fit with no modification and actually came from 87-88 951's. The differences are: brake line tab is mounted on the lower spindle clamp horizontally (86) verses on the body at a 45 degree angle (87), and the accessory mounting tab (for ABS harness, pad wear sensor harness) are oriented slightly different. For concours prepared cars, this might be a hit... all others is simply a slight visual difference. Both have identical brake duct mounting tabs.
Email me directly for details: skip@paragon-products.com
Thanks!
Thanks!
Skip - those arent the ones I sent you are they?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Thank goodness, after what it cost to ship them, I was like OH NO they were wrong! Impressive they still have rebound with 195K miles on them.
wow i'll be sure not to buy an 86... i see they get much dirtier
or should i buy the 86, because i dont want to feel like i have to keep the 87 that clean.... mmm could eat dinner off that strut.
-Michael-
-Michael-
how about an 86 n/a heh.
i read the post a few times but i must just be to tired to figure it out.
is this for a set or just one? when you say two sets of mismatched shocks does that mean there are 4 different ones?
sorry I'll smack myself
No problem, Brett. I have one more set of mismatched struts - one from an 86 951, the other from an 87 951. I am looking for someone who has the 87 or 88 951 that would be returning their struts as cores.
FYI, the 86 na uses strut inserts as normal - you do not need to convert to replace the inserts...
Hi Skip,
The photo at http://www.paragon-products.com/imag...struts_001.jpg is no longer available.
If you have the time, can you post an updated link to the image?
Thanks.
Karl.
Thanks.
Karl.
