barn 924 "barn find"
Old 01-03-2016, 09:35 PM
  #106
Noahs944
Noahs944's Avatar
Ok, this SUCKS & WILL NOT END WELL.
Firstly, the brazing of cast DID NOT WORK. Wrong rod? Not enough heat? Operator error maybe....
So I bought this jar of crap...
Now I'm trying to reinforce it. NOT going to be successful, as one of the cracks just became a hole... I need a manifold or header. Sheeeeet!
Old 01-03-2016, 09:55 PM
  #107
Tiger03447
Tiger03447's Avatar
Looks that way my friend..Good luck with trying to find a good one...from what you said earlier, might be tough to find..
Old 01-04-2016, 07:31 AM
  #108
porscharu
porscharu's Avatar
It looks like the wrong brazing rod was used. The only difference between a braze and a solder is a brazing filler metal becomes liquid at 840*F. It looks like yours wicked out at well below that temp. A successful braze also needs a capillary effect to produce a strong joint so if the crack was ground out this could be the problem. Hard to tell from the pictures. Welding with a nickel rod as mentioned earlier would have been ideal.
Old 01-04-2016, 10:55 AM
  #109
Noahs944
Noahs944's Avatar
Used copper rod that I used for steel tube before.
Old 01-04-2016, 11:01 AM
  #110
Noahs944
Noahs944's Avatar
Decided to stick original 4 speed, because that's how it came from the factory.
Found an army bag, that suits Gramps I think. Planning on doing lots of short drives with tools to see for leaks & whatnot.
Old 01-04-2016, 02:22 PM
  #111
morghen
morghen's Avatar
not a bad choice about the gearbox, never drove a 4 speed 924 but would like to one day.
Old 01-06-2016, 01:41 AM
  #112
Noahs944
Noahs944's Avatar
Old 01-06-2016, 01:43 AM
  #113
Noahs944
Noahs944's Avatar
Old 01-06-2016, 01:44 AM
  #114
Noahs944
Noahs944's Avatar
Yeah, not sure how thing will turn out, but it'll be fun to experience & I suspect the box is rebuilt or nearly new. The oil and the exterior of the case are really nice.
Old 01-06-2016, 04:13 AM
  #115
morghen
morghen's Avatar
if you dont like it, you can always swap for a 5speed.
Old 01-06-2016, 06:22 AM
  #116
J1NX3D
J1NX3D's Avatar
Talk me out of it Noah!
http://www.trademe.co.nz/motors/used...1010970766.htm
not worth $2000 NZD, more like $500
Old 01-06-2016, 07:26 AM
  #117
morghen
morghen's Avatar
wow thats trashed.
Old 01-06-2016, 11:04 AM
  #118
Noahs944
Noahs944's Avatar
J1,
A quick buff & she's as good as new
Every Porsche deserve love, just some of these cars make you work a lot harder before they reciprocate!
Old 01-06-2016, 11:12 AM
  #119
Noahs944
Noahs944's Avatar
So, after a couple of hours scouring the internets I came up empty handed finding an exhaust manifold. I would still like one and maybe one will find it's way to my parts shelf, then one day find it's way under the bonnet. Until day that day comes, MSDS headers will perform the task. Should be here in 10 days.
They say there header kit is a "bolt on but without the oxygen tube fitting", The collector is 2.5"
I don't suspect all will be a simple bolt in because my exhaust already has a cat delete & has been modified by previous people.
2.5" is bigger than stock but will be easy to adapt.
Can anyone provide a link, or simply explain to me the role of the oxygen tube from exhaust to engine? Gramps has that and I probably want to retain it, no?
Old 01-06-2016, 11:31 AM
  #120
odonnell
odonnell's Avatar
I suspect that's a reference to the bung for the O2 sensor.
Found this page: http://www.924.org/techsection/3fuel... Oxygen sensor
Assuming you have one, you're best off welding in a bung downstream of those headers for a good reading. Tip: you can go to your local auto parts store and pick up some cheap spark plug anti-foulers like these:
Amazon.com: Dorman 42009 Spark Plug Non-Fouler - 18mm Gasket Seat, Pack of 2: Automotive Amazon.com: Dorman 42009 Spark Plug Non-Fouler - 18mm Gasket Seat, Pack of 2: Automotive
Spark plugs have the same thread pitch as most O2 sensors.
Quick Reply: barn 924 "barn find"
