New Sunroof seal, now sunroof won't seat properly
Old 09-23-2003, 05:30 PM
Project83-944
Project83-944's Avatar
Default New Sunroof seal, now sunroof won't seat properly
Anyone have any ideas? I replaced the sunroof seal on my car and the sunroof won't sit flush now. Sticks out about a quarter inch or so. Is there a special way that the seal needs to go on or...?
Thanks alot
Old 09-23-2003, 05:43 PM
AndyK
AndyK's Avatar
That's normal. I had the same problem, but now mine seats fine. What I did was place the roof back on the car, pushing it down as far as possible by hand, before engaging the arms. Then, I carefully engaged the locking arms, so that they locked the roof, but didn't raise it at all.
Leave the roof that way for a few days. Then, you can start using the motor to open and close it. Otherwise, you can strip a gear if the roof doesn't seat low enough.
That worked for me.
Old 09-23-2003, 06:27 PM
HY M8NC
HY M8NC's Avatar
mine's been S-L-O-W-L-Y working down. I think it just has to settle in over time.
Old 09-23-2003, 10:36 PM
SoCal Driver
SoCal Driver's Avatar
There are side to side tensioners on most of the sunroofs. Kind of like the wood garage door tensioners. One side or the other should have holes to reach the nuts. Uses an allen wrench -- socket heads.
This will squeeze the sun roof a side to side. Might help.
Old 09-23-2003, 10:44 PM
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
Everyone I've heard of that's done this has had the same problem. Most said that they helped the roof go down with thier hands before they used the motor and set the car in the sun for a few days.
Mine still sticks up but then again it's covered and in a cool garage most of the time.
Old 09-24-2003, 06:28 PM
Singpilot
Singpilot's Avatar
I got my 109 pound girlfriend to sit on the sunroof (mine is an '83, so it's a manual roof). She had just gotten out of the shower, and was naked.
It did eventually fit, and I have not opened it since (my A/C works).
I wish I had taken a picture of this, move over this way honey.... now a little more to the right.....
We still both laugh about what would have happened if someone would have walked in.
Funny, it seemed like a bigger problem before she walked in the garage.
Old 09-24-2003, 07:18 PM
bearone
bearone's Avatar
what about the water spots?
Old 09-24-2003, 07:50 PM
89magic98
In the Sink
89magic98's Avatar
Why, was the garage door open?
Old 09-25-2003, 01:27 PM
jjjr944
jjjr944's Avatar
Singpilot;
Put a new sunroof seal in the 86' this spring and passenger side
of roof still rides about 1/2" higher when closed. Retracting arms are
aligned and but I can push roof down into fully sealed position with arms retracted....hummmm.
Is the 109 lb. force critical to making the s/r seal seat correctly?
Wow.... I thought finding a belt tensioning tool was tough, NOW I gotta find a 109lb girlfriend. Sheeesh! Will try adjusting side tensioners if I can't find a willing assistant.
Well, if the factory recommends it, ya just can't argue.
Anyone out there know why one side would ride higher though??
TIA!
Old 09-25-2003, 03:02 PM
Jeff928S4
Jeff928S4's Avatar
The 109 lb girlfriend tool is a dealer-only item.
At Porsche they cost around $295, but I have heard you can get them at certain "places" for around $100 an hour!
944S Boyeee
Old 09-25-2003, 03:05 PM
89magic98
In the Sink
89magic98's Avatar
944S Boyeee
Don't forget that you have to specify the very expensive "pants-delete" option, or the less expensive "raised-skirt" option, so that you don't scratch the paint on the roof!
Kevin
Old 09-25-2003, 03:20 PM
Jeff928S4
Jeff928S4's Avatar
Yes Kevin - I forgot about those.
Also, I heard that the "totally nude" option is still the best selling, as the nude skin also acts as a mild rubbing compound for the sunroof paint.
944S Boyeee
Old 09-25-2003, 10:33 PM
Singpilot
Singpilot's Avatar
The really bad part about all of this is the maintenance costs of this p-car tool. It approaches the cost of maintaining both of my p-cars.
Best of luck to everyone.
No, I am not willing to rent out the one I have.
Old 09-26-2003, 12:00 PM
jjjr944
jjjr944's Avatar
It's not so much the maitenance but the cost of recalibration. I too had a 109lb version many years ago, put it away on the workbench and came back a couple of months later and low and behold....I had a 159lb tool!
Had to pitch it out and get another dag gone tool...but I think I know where you're coming from! lol
Just kiddin'. But..... has anyone had any luck using the side tension screws to "****" the roof back into seating correctly. Will explore other options until I am conviced the method to this madness works.
TIA
Old 09-26-2003, 12:05 PM
xsboost90
xsboost90's Avatar
i think that if one side is higher then the gears need to be readjusted to make them evenly timed. Also,if it is not pulling down tight, the clutch is prob.. just a hair too loose to pull it down and is slipping
Quick Reply: New Sunroof seal, now sunroof won't seat properly
