frustrated!!!!!!
frustrated!!!!!!
After replacing the alternator because I thought it was bad I STILL have a car that doesn't charge....I admit I am not real bright when it comes to car electrics but I do know the basics.....it starts right up with jumper cables and the "idiot light" goes out while running but there is something causing it to drain and not charge....also, while it is idling (900) the tack will jump up to about 1500 and jump around without any engine speed change....seems like a short somewhere....I guess I will be taking her to our local auto electric shop and see if they can find the problem and probably drain my bank account doing it.........
did you check all the ground straps?? especially the main one from the battery to body and the one to the top of the bell housing?? Make sure these cables are in good condition and the body connections are not corroded. easy to check and worth doing before you take it in to the shop.
Cleveland Rocks
Hey Donn, sorry to hear that you are still having problems. If your local Autozone offers the free testing like most of them do, you might want to have that alternator that I gave you tested (and the battery, too, if you haven't already). I know it was good before, but it had been laying in the attic for a while. If it doesn't test good then get Vince to give you his from the back of his truck. He just left my house about 10 minutes ago, nice guy. Thanks for the hook up.
Wade....I don't think it is the alternator....I will check it out this week....I am thinking it may be the battery or there is a short somewhere.....the tachometer will jump up to 1500 rpm without the engine speed increasing...Vince is a good guy....I shoulda bought your 924 myself.....thanks for the help, though....
I second checking those grounds. A bad or intermittant ground issue will prevent the battery from charging b/c the direct current system actually flows from the positive to the negative side. The whole car is one big circut (meaning there has to be a constant connection from the battery back to the battery). If the ground is bad, the current flow just stops, causing a "drain". That bad ground will also cause the speed and ref sensor signals to be disrupted, causing your strange guage readings.
Sounds like the battery is not holding a charge. I had the same problem I would put the battery charger on it and let it charge all night. Started right up first thing in the morning but by the time I came out of work the battery was dead. Replaced the battery and the problem was solved.
