Trailing arm/spring plate bushings, rubber vs poly for street?
Rainman
Hi,
I need to replace the bushings on my rear suspension soon. The spring plate bushings are entirely shot and the trailing arms can't be far behind.
My car is 30 years old this month so I think I got my money's worth for the stock ones![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I am wondering if going with OEM-style rubber is worth the extra cost vs using the purple Powerflex bushings offered by Ideola.
My car is 100% street driven. Road quality here is crap, and I'm not willing to sacrifice ride comfort for the allegedly sharper handling that a poly bushing can provide due to stiffer compound. I don't want to have to grease anything which puts a potential negative on Poly.
I intend to upgrade torsion bars from stock 23.5 to 26mm while in there, but that spring rate change should be offset in the comfort category by new bushings/maybe new shocks.
So basically this is a question of ride comfort/noise vs cost. I know either option will be better than what I have now which is why I am considering poly. Experiences?
HTML Code:
From what I've read on delrin is that it is squeaky, harder, and wears out faster than rubber...is that your experience?
Another issue is the fitment. Read my post here http://newhillgarage.com/2013/06/13/...sion-bushings/ for the long version but fitting the poly bushing can be an issue.
A lot of engineering goes into OEM bushing design, at least of well engneered cars like Porsche. I am a big fan of OEM bushings if they are available, if you can afford them, and if you are driving on public roads vs the track.
As a counterpoint, our friend Sir Speedy put in the "black" bushings, which are best described as a softer version of the various poly compounds on his S2 and really likes them.
There is no real single answer to this question but that's my 2 cents worth.
Poly/delrin will definitely squeak and the ride will be worse (I have them on the front A arms). I second the "go with OEM" if you can afford it for any street driven car (my car is dual purpose street/track and I have Fabcar lower arms on the front for safety reasons)
I had the same decision to make recently, and I ended up buying Elephant Racing polybronze spring plate bushings, and spherical trailing arm bushings. Whatever about the spring plates, the trailing arm bushings are like the front control arm bushings in that they have to be able to move in more than 1 axis...only rubber or sphericals can do that properly. A solid bushing shaped like the oem rubber one seems wrong to me, form my understanding of how they work.
Unfortunately I haven't had a chance to install them yet so I can't actually offer any real feedback
My theory is that Delrin works best when there is only one plane of movement so on the spring plates there is only up and down, especially if you positively locate the arms to stop any side to side forces at the spring plate. If you fit delrin on anything with two or more planes of motion, like the front a-arms I've found they squeak.
My experience with poly bushings is I had a 80 vette that the diff was leaking gear oil. So I pull the diff to reseal it. I noticed the front diff support was hammered, so I replaced all the diff support bushings with poly bushings. And while I was in there, I replace all of the rear suspension bushings with poly also. Well between the harsh ride and drive line noise transmitted to the frame a month later that car was back up on jack stands and replaced all that poly stuff with good ol' rubber. Didn't like doing that but, when I did the bushings in my Porsche, you can guess what I used. And thank the good lord for Elephant racing rubber spring plate kit, otherwise I would have been wrapping that spring plate with a bicycle inter tube.
One thing I would like to add is I live in New York and the roads are rutty. My folks live in Florida. They got some nice smooth roads down there. So road quality may sway peoples opinion on what to use.
