help with brake caliper identification
Old 10-16-2014, 04:08 PM
apitts73
apitts73's Avatar
Default help with brake caliper identification
are my vented disk rotors and calipers transferable to the 968? im trying to figure out which calipers i have...ive seen the post about the differences between the 3 sizes...but when i measure the caliper its only 10" from end to end and 6" wide. the rotors are 12". according to the post "Warning: Caliper **** Ahead"...the stock turbo calipers are 298x28mm...but when i measure mine they r only around 10"(254mm). i must be measuring the wrong way! they do look pretty large!
thanks again for any info
Old 10-16-2014, 04:22 PM
Dougs951S
Dougs951S's Avatar
I dont understand how you could measure wrong..its just a diameter measure across the center of the rotor. No way you have 10" rotors, even stock NA rotors are bigger than that.
Old 10-16-2014, 04:45 PM
admiralkhole
admiralkhole's Avatar
Wait.... Are you confusing rotors with calipers?
Old 10-16-2014, 05:09 PM
apitts73
apitts73's Avatar
i measured the rotors...they r 12" in diameter. its the caliper i cant figure out. i measured from end to end of the brake caliper and it was 10". i just went and measured again.....just under 10".
i must b measuring to wrong way!!
Old 10-16-2014, 05:27 PM
fejjj
fejjj's Avatar
Post a pic.
Old 10-16-2014, 05:29 PM
apitts73
apitts73's Avatar
hope this works...two pics of where im measuring from
Old 10-16-2014, 05:30 PM
apitts73
apitts73's Avatar
they are plasti-dipped in red...originally they are black
Old 10-16-2014, 06:07 PM
admiralkhole
The "3 different sizes" might be referring to the piston sizes in the calipers. '86 951 has 38/36mm pistons, '87+ 951/S2/968 have 40/36mm, and the M030 calipers have 44/36 (?) I think.
Old 10-16-2014, 06:21 PM
Dougs951S
Dougs951S's Avatar
the 298x 28mm you quoted is a ROTOR spec, for stock 951 brakes. What you have there are appear to be stock 951 calipers with most likely 38/36 pistons. They are meant to take a 298 x 28mm rotor.
Old 10-16-2014, 06:22 PM
fejjj
fejjj's Avatar
Those are NOT M030 calipers so you should be fine.
If you are doing a 968 Turbo build then you will want to upgrade to at least M030 calipers.
Old 10-16-2014, 06:24 PM
apitts73
apitts73's Avatar
look at the post..."warning: caliper ****"....#14 post on pg 1 of the thread........i think they are referring to the length of the caliper....i think!
Old 10-16-2014, 06:29 PM
apitts73
apitts73's Avatar
that makes sense....so calipers are measured by the rotor size??
Old 10-16-2014, 06:55 PM
fejjj
fejjj's Avatar
Calipers are measured by the piston sizes.
Old 10-16-2014, 07:14 PM
apitts73
apitts73's Avatar
ok...this is making sense to me.
are they equivalent to the 968 brakes or smaller than 968?
according to the **** caliper thread the 968 are same as turbo s.
Old 10-16-2014, 07:52 PM
fejjj
fejjj's Avatar
968 NON M030 calipers are same as 88 944 Turbo NON S.
944 Turbo S are the same as 968 M030.
Quick Reply: help with brake caliper identification
