Spacer Advice?
Old 07-26-2014, 09:25 PM
Euro 928
Euro 928's Avatar
Default Spacer Advice?
Hello, My son has a '85 944 NA, with the stock cookie cutter rims. He has purchased aftermarket rims, and is in need of spacers. Where can we purchase spacers foe his vehicle?
Thanks,
'85 Euro 928
Old 07-26-2014, 09:35 PM
admiralkhole
admiralkhole's Avatar
What are the offsets? Are you wanting spacers and longer studs or adapter (spacers with studs)?
Old 07-28-2014, 01:18 AM
Euro 928
Euro 928's Avatar
Unfortunately we don't know the offsets because he purchased aftermarket rims from a private owner. We don't know which one we want, spacers with longer studs, spacers or adaptors? Can you advise us on where to purchase either?
Thank you.
Euro 928
Old 07-28-2014, 09:54 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
You're gonna need to know the offsets and widths. I would suggest adapter-style spacers as they are easier to do. Some will claim they're unsafe but I haven't seen anyone actually have them fail.
They're the ones that look like this:
Usually can be found on ebay for under $100 a pair.
I would recommend this website www.willtheyfit.com to enter the old and new specs into to help decide what offset puts the wheels at the same spot as factory (or desired spot).
Hope that helps.
Old 07-29-2014, 04:35 AM
James Chimney
James Chimney's Avatar
in most cases (with phone dials) the size is on the inside, take a look, the issue I had with spacers was getting them to sit evenly, best I could get was tighten each nut slowly and evenly, still had a bit of a shake at speeds
Old 07-29-2014, 07:22 AM
admiralkhole
Yep, wheels usually all have the sizes (diameter, width, and offset shown most likely as etXX) on the back... It's cast or stamped in. I've come across ONE set of wheels that didn't have the offset displayed correctly but it was easy to figure out.
James, it sounds like you need hub centric spacers. Your spacers look like flat plates I'm willing to bet.
Old 07-29-2014, 10:29 AM
MAGK944
MAGK944's Avatar
Just buy some washers and fit them on the lug studs one by one until you get the wheel fit you desire. Then measure the stack of washers and get spacers and studs to match.
Old 07-29-2014, 10:46 AM
FrenchToast
FrenchToast's Avatar
Remember if you get adapters then you have extra lugs to check.
Old 07-29-2014, 11:35 AM
admiralkhole
And you'll want to re torque them after so many miles or something like that. I've checked mine periodically and had never had any issues.
Old 07-29-2014, 09:05 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
That is a good idea!
Old 07-29-2014, 09:48 PM
Dougs951S
Dougs951S's Avatar
Ditto. I have the bad habit of putting on my lugs with my 1/2" impact, I've checked them all and they are definitely not going anywhere
Old 07-30-2014, 04:33 AM
Euro 928
Euro 928's Avatar
I'm so disgusted, I don't know what to do. The rims are MHT/Foose custom 3-piece, 8x19 front, 11x19 rear. The previous owner had them on a Porsche Boxster. I went to two national tire dealers, Discount Tire and Belle Tire. Neither had anyone in their employment that was skilled in measuring the rims to tell me the offset. I contacted the manufacturer's customer service rep and he could not tell me the offset of these rims either. Please advise?
Old 07-30-2014, 04:39 AM
Euro 928
Euro 928's Avatar
I don't think knowing the size of the phone dials is going to help me with these custom rims. These rims are a total different style and offset than the phone dials. We looked on the inside of the MHT/Foose rims but there is nothing telling us the offset.
Old 07-30-2014, 04:47 AM
Euro 928
Euro 928's Avatar
Ingenious! I will do exactly this but still confused as to spacer and longer stud, adapter style, and where to purchase either.
Old 07-31-2014, 01:00 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
You can go either way, I believe most go with adapters cause its easier. They can be found on eBay just do a search.. and I guess youre stuck with the washer method. Slap em on the car and start counting washers!
Quick Reply: Spacer Advice?
