Bought an 86 today
Got the cylinder head off tonight and found four bent valves. I found that the belts were intact but that they were damp with oil and coolant. Perhaps the belt had slipped and jumped a couple teeth and bent the valves due to the contaminants on the belt. Here are a couple pics. I will get some more later of the head.
Guess, in the back of my head, figured it would be of little use to post a photo of the cam belt, with its tensioner released, if we were trying to ascertain the root cause of bent valves.
Let us know what you find.
Thank you. I thought it was a fair deal. I knew it needed engine work after hearing the engine crank over. But the body and interior were so clean, I thought that it wasn't a bad deal.
Its a really clean car. Once its back together I will post more pics of the car overall. Right now, its a little tough in the garage. Waiting on more parts though and I need to take the head to a machine shop to have teh valves done and to have the head milled.
Been awhile since I've updated. Yesterday I got my head back from the machine shop. Its all cleaned up with straight valves and new valve guide seals. I have some other prep work to do before the head goes on today. Hoping to have it bolted on tonight. Any tips would be appreciated since this is the first 944 head job that I've done. Here are a couple pics of the head:
Made some good progress tonight. I was able to get the head on, get the exhaust bolted in place, replace the bypass hose and clean the cam box. I still need to install new seals on the cam box before I install it, but I'm happy with the progress I made tonight.
Head gasket set on and head ready to install:
Head and exhaust manifolds installed:
Bypass hose replaced:
Cam box exterior clean:
