Euromeister 17" Fuchs Replicas - Feedback?
I think 18s fit the car very well.
Money shot...
I think the issue is that if you look at the inside of the "petals" of the 951 specific Fuchs, they are carved out more compared to the 911 part# Fuchs that they use as the donor centers.
Several years back I posted comparison photos of the differences between the two versions but I can't find them now.
I bet they would fit my car with the current aggressive stance I have...too bad i'm putting a clutch in it right now.
Former Vendor
Here's the setup I was planning for my early offset NA (1985.5)
Euromeister Replicas
Front: 17 x 8, ET 10.6
Tires: 205-50-17
Rear: 17 x 9, ET 15
Tires: 255-40-17
Now here's the rub (pun intended). I have all the parts required to swap out the NA brakes for a turbo brake upgrade, hubs, spindles, rotors, calipers etc. Planning on swapping them out in the future once I rebuild the Brembos. Any anticipated interference / rubbing issues? Spacers etc?
Tires: 205-50-17
Rear: 17 x 9, ET 15
Tires: 255-40-17
Former Vendor
I've run this through a few online offset calculators and the net result is that the 17x8 fronts will sit in 1mm closer on the inside and extend an additional 23mm out. The 17" rears will sit 5mm closer inside and an additional 21mm out. Obviously that's just the rim edges and do not account for the tire size.
