Checking rear suspension for looseness, wear
Hi all,
As my 1992 has 160K on it I want to check out my rear suspension. Any suggestions on what to look for, places to pry for deflection, etc? I have no clunking or anything but I feel the car feels unsettled and tramlines more than I like.
Thanks,
-Joel.
Thanks,
-Joel.
Rainman
tramlining is largely a function of tire pattern/alignment.
mine went away entirely when i switched from BFG g-force tires to falken 912s.
as far as suspension wear...it's probably worn regardless, after 160k miles and 22+ years of heat cycles.
would it be excessive to use a come-along attached to a trailing arm to check bushing deflection?
Former Vendor
Based on age and mileage, the spring plate bushings will be toast.
Measure the gap on the spring plate tube portion where it pokes through the spring plate cover. It's supposed to be concentric. You will find the gap up top is less than the gap on the bottom. Do the measures with the wheel loaded at static ride height. In extreme cases the spring plate will contact the cover plate.
This non-concentricity is due the bushing be deformed and worn. It no longer functions properly when this happens.
Thanks, I will look at the spring plate bushings... but would not a loaded bushing have some deflection regardless of age?
I dunno about a come-along but a ratchet tie-down might be employed. No idea how I might tell if I am putting on, say 500 lbs of force or 1500 without a strain gauge.
One thing that might work: I could put the parking brake on and pull the whole car forward and back while measuring from fixed points to the wheel center. I could not really bend anything that way as I'd be limited by traction and brake effectiveness. If the parking brakes are not good enough I can use the mains and park the front wheels on some cereal box cardboard.
If one had a steep driveway this would be really easy, just hang the car off a come-along or ratchet strap (with a backup tow strap and nearby chocks for safety) and lower it a bit with the rear brakes set, then measure the rear toe and the wheel center wrt some fixed points, then pull it uphill a few millimeters and measure again.
An old tire a few inches away to catch the car if it gets loose would be sensible.
-Joel.
-Joel.
Former Vendor
Update: I have not tried loading the rear suspension fore-and-aft but I did look for deflection of the torsion tube bushings. There is less than 0.5mm difference top to bottom, so I think they are OK. I could not find any other signs of significant wear.
I think I had too much rear toe and some cross camber. I believe I have a better rear alignment now and I will get more driving data soon. I have new tires but I want to get everything sorted before I put them on. The old tires might never handle right at this point but I still want to see how good I can get it.
Hmmm, OK. I am doing my own alignment, and will be checking tire temp across the tread to make sure I am not excessively wearing the new tires.
I suppose there might be a way to measure toe that would change with different tires but I have not quite clicked on what it would be.
