Can you help ID these 924S parts? Nessessary or not?
Not sure what they are. I am cutting out everything I can in this track only car. push button start and on/off switches for most systems.
https://plus.google.com/photos/11772...72574991177521
it is the bottom three pictures.
what is the plug on the drivers side firewall/shock tower on the plate?
what is the plug on the passenger side shock tower?
what is the round thing by the DME plug?
Thanks,
Pete
Thanks,
Pete
First pic is the diagnostic port for the ECU
![](https://lh5.googleusercontent.com/-c9Cv1PQmAV0/UzMyAt_G8OI/AAAAAAAABr8/d0g-IiM_kW8/w1358-h764-no/20140325_174503.jpg)
Second is for the Cruise Control servo
![](https://lh5.googleusercontent.com/-pTVxjcnhYfw/UzMyBbxhMjI/AAAAAAAABsI/QZGweCR8Bhc/w1358-h764-no/20140325_181108.jpg)
Third I think has something to do with the HVAC system, but it could be for the ECU to read the air pressure to determine altitude.
![](https://lh3.googleusercontent.com/-oMStga55aJ4/UzMyB8ULNaI/AAAAAAAABsM/UvVYgzT3Cp8/w1358-h764-no/20140325_184433.jpg)
The altitude sensor is a binary switch. Over (dont quote me) 3500 ft it reduces the fuel load by 4%. It is wholly worthless in my experience and I have seen only a handful that still worked.
Yeah, it's just an open circuit under normal operation, so just pull the thing.
