Compression Numbers: How good?
Compression Test Results: 1986 944 Turbo, 115,000 miles.
148 (cylinder 1, nearest to belts)
151
147
149
How good or bad are these results? I know consistency is good, but should I be getting higher numbers?
I'm not sure what is considered "wet" or "dry" testing, but all I did was put some oil on the threads and o-ring of the testing equipment, and cranked about 8 times each. It's a free rental from O'reilly auto.
Cheers
151
147
149
Cheers
Silly question. Why do leak down test if compression is good? If compression is bad, I get doing the leak down to determine the cause of the compression loss (intake valve, head gasket, rings, etc.). Not sure if I understand why it should be done otherwise.
Not being snarky, just want to understand your thought process.
Bonus, I've never heard of a stock 951 (even with very low mileage or a fresh rebuild even) pulling anything close to 180 psi. A 8:1 comp motor just wont pull those kinds of numbers. Thats more accurate for a very healthy 10.6:1 2.5 liter N/A car. 150-160 is very healthy for a stock turbo motor.
Thanks doug, I appreciate that info!
Bum, i'm still learning but I think a leak down test differs because it tells not so much about peak pressure generation, but rather about the cylinder's capabilty of maintaining a pressure. Slightly different pieces of info, I guess.
For example you might have nice and even compression numbers around the 150 mark across all cylinders but still have a leak down over 20%. Indicates some even wear on all cylinders and that on a fresh rebuild the compression numbers would be higher.
So, a compression test alone just tells you that all the cylinders have worn evenly and that you don't have a bad leak on any one cylinder.
