Catalytic Converter
Old 08-12-2013, 11:52 AM
Mueller944s2
Mueller944s2's Avatar
Default Catalytic Converter
I have this VERY irritating rattle at idle and below 2k rpms. It's coming from the middle of the exhaust by the cat so I figured it's probably shot (as is the rest of my exhaust, the end of the muffler is rusted out as well). I've been told by DC that it's illegal to sell used cats (I think, maybe I misunderstood?). So, I guess I need a new one and have it welded on. Since I'm in there and all, is there a high flow cat that yall recommend that would bump up the power even a little? I don't want to change the sound because I love the S2's deep rumble. Since I do a lot of highway driving I'm kinda turned off towards the test pipe, not sure how that would change the sound. Any suggestions?
Old 08-12-2013, 12:49 PM
mytrplseven
mytrplseven's Avatar
I've heard that resonators work really well in that application. Muffler shops have them.
Old 08-12-2013, 12:59 PM
F40LM
F40LM's Avatar
Use the SLP 'Mustang' resonator. I think Odur came up with the 'design'.
Search 'clone my exhaust'. It's the resonator I used, I really like the change in note.
michael
Old 08-13-2013, 01:35 AM
Mueller944s2
michael
How was the change in sound?
Old 08-13-2013, 10:52 AM
mytrplseven
Went from a "B flat to an A minor"
Old 08-13-2013, 02:12 PM
Mueller944s2
any bump in power?
Old 08-13-2013, 02:34 PM
Gator944
Gator944's Avatar
I use the slp resonator and think it sounds great.litte more power..not much but a little..sounds good tho. $69 at summit.
Old 08-15-2013, 12:02 PM
Mueller944s2
I'll look into the slp. Any experiences with test pipes?
Old 08-15-2013, 05:35 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
...It's the resonator I used, I really like the change in note. michael
https://rennlist.com/forums/924-931-...-heaven-3.html
test pipe vs SLP = horrible vs epic
video (somewhat close to the actual sound)
https://rennlist.com/forums/924-931-...-heaven-4.html
Butters snapped a photo of his setup;
Originally Posted by Butters944
Well, I went ahead and did up Odur's exhaust on my 944. Louder than I wanted it but I LOVE IT!
Went with the SLP resonator, 2.5" pipes all the way, with a 14" flow-through knockoff-magnaflow muffler in back. Total $ for entire project including having it all welded up at an exhaust shop: $300. Not bad, eh?
oh, and srsly, does anybody run a cat anymore?
Old 08-15-2013, 07:51 PM
Mueller944s2
Great stuff! It looks like Butters is only running one resonator? I'm thinking of just ordering the SLP. My muffler is completely shot too, so I'll need to order another one. Would you recommend running with both resonators or deleting one?
Old 08-15-2013, 08:22 PM
odurandina
Team Owner
odurandina's Avatar
run a the SLP near the front in place of the cat,
then an 18X8X5 inch magnaflow back there (a bump up in size from Butters'.
but build it like how Butters has his system set up.
the sound it will make on the highway will be soooo good, you'll never want to play the music.
Old 08-15-2013, 08:44 PM
Mueller944s2
How loud will it be compared to stock? Most of my driving is highway so I'd like it to be comfortable in the cabin
Old 08-15-2013, 08:57 PM
odurandina
Team Owner
odurandina's Avatar
Old 08-15-2013, 09:07 PM
odurandina
Team Owner
odurandina's Avatar
the SLP cleans up the sound, but as it is completely hollow, it doesn't suppress the noise as much as a full-sized 14X5 or 18X5 inch glasspack resonator would do.... so don't run the SLP... run a full glasspack like the one shown below.
and still run the large muffler (everyone makes the mistake of running too small mufflers).
these things aren't very heavy, so there's not much of a problem with weight.
then you'll have a semi-exotic sound that's not be too loud.
these would also be really nice set up for an S2 or 968 and make good power....
Old 08-16-2013, 11:34 AM
odurandina
Team Owner
odurandina's Avatar
exactly.
Quick Reply: Catalytic Converter
