where does this heat shield go
I am putting back together my 91 s2 and don't remember where this heat shield came from.
Any help is appreciated. Pictures even better.
Mark
Mark
Looks like the one that protects the motor mount. I'll try to attach a PDF with a picture, its number 15 on the Parts document. My pdf is from a 968 but you will get the idea
Ok got it, it bolts on the crossmember. My crossmember is not in the car yet. Should I install it on the cross member before mounting it or after. Which is easier?
Thanks allot for your help!!
Mark
Mark
Yes, This is very easy to access and put on. I've done it before with all 4 wheels on the ground and the fronts turned to the left. It's not a big deal. Rear side of the pass-side of crossmember. The top hole is not (I think) visible if your car is on the ground.
