FS: 1986 944 Turbo Zermatt Silver
I have a 1986 Posche 944 Turbo that I wish to sell or possibly trade. Car has a lot of maintenance done roughly 5K in the past 4yrs. This car also has a good amount of modifications done for more power, it's not perfect and needs minor things but passes yearly inspection and I drive it daily. Miles are currently 195k range but i drive it everyday and a few long 600 mile round trips.
Mods:
New Garrett 57 Trim Turbo Stage III Turbine, 16Psi Currently
3 Bar FPR
MAF and Tune By Roguetuning.com C-Tune
3" Catless exhaust downpipe back
80lb Injectors
Mbc
Custom Machined Coilovers with 300lb Springs (Front) XSCHOP
CRP Urethane Splitter
17" Cup Replica's 8in Front 9in Rear
968 Fiberglass Replica Spoiler
Lindsey Stage V Nose Panel
Maintenance:
Clutch 8/01/09
Cap and Rotor 8/17/09
Ignition Coil 8/17/09
Spark Plugs 8/19/09
Tires 2/15/10
Vac Lines and Venturi Delete 5/13/10
Fuel Pump 7/25/10
Rear Shocks 8/11/10
Idle Air Valve 8/20/10
Rear Right Wheel Bearing 9/05/10
Oxygen Sensor 09/05/10
Fuel Pressue Regulator 5/25/11
Mass Air Sensor 5/25/11
Map Sensor 5/25/11
Fuel Damper Hose 7/20/11
Timing Belt/Balance Belt/Water pump 10/21/11
Serpentine Belt 10/21/11
Wires 1/15/12
Front Strut Assemblies 5/15/12
Fuel Injectors 4/10/12
Front Wheel Bearings and Seals 4/13/12
Throttle Switch 4/13/12
Intercooler Coupler Kit 5/17/12
Steel Arm Converison 10/01/12
Ball Joints 10/01/12
Control Arm Bushings and Castor Blocks 10/01/12
AOS Seals 2/08/13
Crank Sensors 4/26/13
Garrett 57 Trim 5/10/13
Radiator Hoses 5/29/13
Bad:
Will need a Rear Driver Wheel Bearing Eventually
Heater Hoses Need Replacing (Have Silicone Ones Not Installed Yet)
Valve Seals Are Leaking Some (After Boost Runs)
Paint (Clear Coat Flaking on Roof/Passenger Quarter
A Few Dings Present Worst is Driver Fender
Interior Needs Some Love TLC
Hatch Rattles Needs New Top Trim Piece Rest is Good
Oil Leaks (Have a Top End Seal Kit Not Installed)
Price: 3,500 FIRM
Mods:
3 Bar FPR
80lb Injectors
Mbc
Maintenance:
Clutch 8/01/09
Spark Plugs 8/19/09
Tires 2/15/10
Fuel Pump 7/25/10
Rear Shocks 8/11/10
Map Sensor 5/25/11
Wires 1/15/12
AOS Seals 2/08/13
Bad:
Price: 3,500 FIRM
you mention trade, what would you consider?
offered: 1992 Dodge Steath Turbo(mitsu 3000gt vr4 sister). AWD, 300+hp, has no cat in exhaust, however a custom bolt in cat is with the car. as is another set of stock rims, and optional rim set from a mustang(not factory mustang, 255/17 front, 275/17 rear). upgraded front and rear brakes. does need paint and possibly a tune up, i'm in the midst of ordering parts for that. new tires(april 2013, same time as front brakes.) i'm huge into the 3/S community, I just miss my 944. i'm up for a car that can be a lil project as I go. just over 123k on the stealth.
my car is probably worth more than the 4k you're asking for your 951, but eh.
if a deal was reached, could you provide a list of places any aftermarket pieces come from(as I would you) so if replacement is needed I can get the right part
