Replace Rear Cam Tower Gasket in Car
I had a small leak on my rear cam tower gasket and oil was getting on the headers and smoking. I replaced the rear cork cam tower gasket and now my small leak has become a larger leak. I may need to do this again. Any hints/tips?
Since I am doing this with the cam tower in the car, there is very little room to get the torque wrench in there. I think my problem may actually be that the tight fit caused the rubber behind the cam tower to put more pressure on the torque wrench and and make me think it hit the 7 lbs before it actually did. Therefore I must not have enough torque on the bolts.
How do you do this with it in the car?
Thanks,
Michael
86 951
Thanks,
Michael
86 951
I just wanted to make sure I didn't over torque it. Last thing I would want to do is strip anything. I used hylomar on both sides of the cork gasket.
torque wrench..hahha. Put the gasket in- tighten it with thumb and pointer finger until all three are snug. Drive car, then retighten. The cork heat cycles and gets soft, making them leak again. May take a drive or two to get it to stay tight. Torque is not the issue. Actually if you try to over tighten right away it'll just split the gasket. All else fails, Lindsey Racing sells a non-cork gasket.
Proprietoristicly Refined
RL member massive put a few DIYs on RL.
Few use the forum:
https://rennlist.com/forums/diy-submission-forum-135/
Here is the cam cork gasket DIY by massive:
http://www.944foot2thefloor.blogspot...ng-gasket.html
John
Few use the forum:
John
My method... evolved over several events. Car up (wheels maybe 10 inches of the ground). Three small bolts - throw two of them away, and buy two m6 studs about 1 inch long and two new nuts. Get the cup and old gasket off. (From under the engine) Insert two studs, just thread them in. Hang the new gasket (which I think are perfectly fine) on the two studs. Hang the cup and engine hanger on the two studs - they will hold onto things temporarily. Put on a couple of nuts, then the last bolt. snug them up. done. Its a pain but doing it twice from above sucketh...Bruce
