944 turbo cv axle - marbles....
The usual driverside side inner assembly let loose yesterday. The car is a 1987 944 turbo and has about 335 hp and torque and use it at the track.
I would appreciate axle recommendations. Which ones to avoid? Also, could there be something else contributing to cv joint axle failure?
I read many posts about mixing and matching cv axles and joints and now I am thoroughly confused.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Check out Lindsey Racing for heavy duty CV Axles.
http://www.lindseyracing.com/LR/Parts/944AXLELB.html
Cheers,
Larry
Cheers,
Larry
i ran factory axels from paragon with my turbo- about the same hp, maybe abit more. Blew one up immediately and ended up going solid trans mount- never blew another up. Noisy solution- you can also go semi solid or do the eurethane trick like i did to my spec car. Some even have actual braces from the body to the trans.
Look at the parts equivalent thread... some people running the super inexpensive Vanagons on higher hp apps at the track and no problems. The one I am running is no problems so far too (<300hp though)
