Interesting 924 v8 at local Pick Your Part
Attachment 672726
Attachment 672727
This was at the Pick your part on Katella in Stanton, CA If you live close by and want to check it out.
Attachment 672727
Rainman
IIRC Renegade used to sell a 924 SBC crossmember that bolted to the sway bar mounts and the 924 factory crossmember...I saw one welded on once as well. If you pick the strong parts of the rails (or strengthen them)...go for it.
The bellhousing and flywheel/clutch would be nice items to grab too.
But usually v8 swaps are supposed to be hot items to sell, not junk to throw away at the wrecking yard, so I wonder what was so wrong with it.
I'm curious if it's bolted up to the Porsche transaxle, or if they just cut the tunnel out, slapped a TH350 (GM trans) behind it, and then swapped in a rear axle...
