Balance Shafts
Balance Shafts
I hate these things, they are annoying to time and I can't seem to stop the belt noise from them.
How bad is it if you install a LR balance shaft delete?
How easy are these things to fit, is the job just done from the front of the block?
I'm tempted to get rid of them when I have to re-tension the TB in 1000 miles!!
thanks
Kim
thanks
Kim
I've got very little noise from my balance shafts. Tensioned using the Arnwerx tool.
https://rennlist.com/forums/924-931-...ete-views.html for some feedback on Balance shafts. There's a ton of threads asking feedback on balance shaft deletes, just use the search tool
I used the LR delete kit. I have been running my car without balance shafts since June. I didn't notice vibration issues like some have stated. But then again I also converted my water pump to an electrical one and removed the mechanical pulley. The process of removing the balance shafts is easy and a pain. The top one on the drivers side you remove the fuel rail and injectors along with the intake manifold and it is easy to get to. The bottom passenger side you have to remove the motor mount to get room to get the cover off. You can get all the bolts loose but there isn't any room to remove the cover of the balance shaft. Believe me I tried for a good 2 hours till I finally decided to remove the motor mount.
If you do go that route get the locite to seal up the ends. Again concerning the vibrations, mine may not have been as bad because of the water pump. But I still instead to reinforce my oil pick up and fuel rail/lines. Hope this helps.
Can the shafts just be left in place with no belt? I used to build and race some
fairly high hp Chrysler 2.4's (500-600hp), some of the guys removed the shafts some left then in and just removed the chain. No ill effects in either case.
The way Porsche designed these seems a bit complex and problematic.
Steve
Steve
From what I have gathered from others if you just remove the belt, the shafts will eventually start to leak oil. I guess it creates the seal while its spinning. But you could probably get away with just smearing a sealant over it. Although it won't be pretty and I do not know if it would work or not.
much faster then with it in place. Did you notice a differance on your car?
Steve
I didn't dyno the car but I certainly noticed a difference.
true, however four cyinders firing a recipricating mass of about 65lbs (not accounting for flywheel, pulleys, ect.) will have a higher energy potential than a waterpump pulley that maybe weighs 4lbs and simply spins on its axis. not trying to get into a pissing match, just putting things into perspective.
The water pump pulley weighed like 2 pounds if at all haha. But it makes me think too of the pressure build up from heat and the resistance of water flow. Although I do not think that would cause frequency as much as drag. (Just thinking out loud)
My car still has a little vibration at around 3000 rpm, I thought the balance belt timing might be off but i've checked it over and over again and its right, I didn't consider that you could just remove the belt.
It would seem that would be a great way of deciding for yourself before you go ahead with the whole job, I can just remove the belt when I do my re-tension and see how I like it then if I don't I just refit the belt, right?!
