Steering rack DIY swap 968
Hi
my father is in the middle of a steering rack swap (DIY) on his 968. However, he didn't check the new alongside the old...and hence the new is in, but it is nearly 2" short on either side.
I suspect he got a steering rack from a 924 perhaps? Anyway, what are his options now, are there adapters to extend them on either side as workaround solution?
Thanks for any help.
thanks, he doesnt think he has the tools to remove the tie rod ends and I'm in another part of the world so I cant help him. what is involved in swapping tie rods, what are the steps?
Its very straightforward but it can be a real PITA without a good bench vise sometimes.
Depending on his age etc it may be worth it to just have him drop off both racks off at an alignment shop and pay them say $20 to swap them over.
The rest of the swap should be fairly easy.
michael
michael
Anyone know where I could find exploded drawings or similar so I can guide him through what tools etc.? The place where he got the new rack acknowledges they probably sent him the wrong item and will pay for a swap. Easiest would be if a guy could come home to him with the right tools...
You need 19mm, 32mm & 22mm wrenches. A bench wise helps a lot.
19,22 & 32mm of these
And this helps a lot
This is also a useful tool
As you can see, most likely your father have all necessary tools to accomplish the job.
http://www.clarks-garage.com/
There is a good write up on Power Steering Rack Replacement in the Garage Shop manual that discusses tie rod removal and replacement.
Edit: Just figured out how to post a direct link
http://www.clarks-garage.com/shop-ma...ure-index3.htm
