944 oil pick-up tube "collar"
From other thread:
Picture is worth more than words
First picture is properly mounted band (from google images) and second is mine and what I'm trying to say. The pickup is lower than the band so what's the point? What does one acomplish with closing off 30%+ of mesh screen?
hahaha... okay.
All I see is screen, something meant to keep the naughty bits out of a suction device. if the whole pickup tube was a mesh material, would it work well or work it not provide vacuum?
-Anyway, maybe it doesn't matter, maybe I'm wrong You build your engine in the way that pleases YOU. You do beautiful work with exceptional detail. I just realized 951and944S has basically the same argument as I do, didn't mean to rant, just thought I might be able to make a difference, but it's already been said.
Hope you have a great weekend. Lets hope we all keep our cars rubber side down.
AND BACK TO OUR REGULAR PROGRAM.
So what's the point of the band?
The band forces oil pickup lower in the pan and prevents sucking from sides.
For track cars you want the trap door, a windage tray, oil pickup tube support brace and crank scrapper.
This is getting ridiculous. HOW CAN IT SUCK FROM THE SIDE??
The pickup is already LOWER than that band.
The ring prevents oil and air mixture, air entrainment in the sump oil, from entry in the oil pickup tube because the available screen surface is substantial below the oil surface is a high G right hand corner. At the intersurface between the oil in the sump and the oil in suspension above the sump, are oil molecules containing air, thus froth created by the rotating crank impacting the dropping oil molecules from the cavity of the engine into the interstitial space for the crank. These droplets of oil and air land on top of the oil sump surface and it takes time for the oil to release the entrained air. The ring provides the buffer for the time it takes for entrained air to be released and thus the oil in the pickup tube is all oil molecules with no entrained air. The ring is not needed street car.
No it does not prevent air and oil mixture, it can't do that. If anything ring first traps air bubble when oil is filled which is then sucked in after initial startup and from then on it does nothing at all. In case when tube is bent and lower than it should be it can only become a restriction because circumference in later oil pans.
The best possible pickup would be just tube with venturi on the end but because crude mesh filter is needed it is added by the factory in shape of mushroom to maximize surface of the filter.
What this band does is just minimising surface of this filter and absolutely nothing more.
Available screen surface has nothing to do with pickup itself. you can extend screen surface to periscope like tower out of the car and it wont affect pickup point the slightest bit.
Once and for all, either do this physically or try to just imagine the result.
Take a container of oil about an inch deep, shallower than the side depth measurement of the pickup end's side mesh as it sits bottomed in the container..
Make an adapter, using a handheld vacuum pump, try to pull oil up the tube.
Not gonna happen, you will only suck air because it is lighter and less viscous than the oil.
Now ring skirt the pickup as you have been shown 100+ times.
Same experiment, bottom of mesh resting on bottom of container, only now there is no side mesh open to atmosphere.......you will get oil, not air pulling up the tube towards the vacuum source.
Do you get it.....?
Are you gonna drop this now.?
Go google any "high performance" sump pickup and you will see they are already of this design or even more evident to the benefit, some manufacturer's have "revised" their pickups to be of this design where they previously weren't.
Just let it go......if you want to use it use it.
If you don't then don't.
In another thread you stated that it was not only not beneficial, but that it was detrimental.
Then I showed you a car with the baffle and ring kit turning 80-90% duty cycle at over 5-6000rpm around an undulating track with high grip corner Gs in a 1.5 duration enduro (read HOT oil temps).
When I asked you to explain how exactly, an already iffy oiling system for track duty can survive this with a detrimental add on, you went to sleep until 2 months later.
Are there better possible designs, like a custom oil pan....., external oil supply delivery to the front pump's suction, dry sump, etc.., etc...., yes,. there are.
Racing sanctioning bodies do not allow these or everybody would have dry sump.
Just this past year I petitioned 944Cup head to at least allow an external pump and was denied.
Everyone I know that races a 944 variant engined car uses this baffle and ring kit. Not because of lemming mentality......because the theory is sound.
So try the experiment and make your choice.
Then leaved the issue alone.
Or I'll be back to taunt you a second time.....
T
Lots of words and no substance. I think you and anybody that believe in this snake oil pickup modification really could use some more fluid dynamics lessons.
You said it lowers the pickup approx one inch. Can you explain how so? it extends beyond oil pan?
Pickup is at lowest point at the oil sump as is from the factory. The band doesn't lower it.
Some cars have simpler pickups where this kind of mod actually lowers the level at which oil is sucked in but not in this instance because porsche.
Baffles are effective, some more, some less. I'm not saying baffle is a bad idea but additional baffle on late oilpans is also absolutely not a necesity for race car as many cars are doing super fine without it.
Here's just one RL example: https://rennlist.com/forums/racing-a...n-baffles.html
Dont want to get involved in the may lay... But another preventive measure that I took was Drilling holes under the main crank bosses. Out scrapers are tight and there is allot of oil being slung around at high revs. The Air behind the piston needs somewhere to go. when it has nowhere to go it forces air into the pan and "froths" the oil like Starbucks. Porsche addressed this issue with the 968 engine by adding holes to the bosses, allowing air to be transferred from the piston coming down to the to the adjacent Cyl where the piston is going up... This prevents "cylinder pumping" That said, when was the last time you heard of a 968 rod failure? Also, if there is a "choice" when taking a left hand turn between downshifting and making the engine scream while in the corner or leaving it in the higher gear, Go for the higher gear and be nice to your engine. At least in club racing, prize money is the same no matter where you finish, but a spun bearing significantly reduces the prize money.... My .02
