Electrical water pump????
These have been around for a few years now click here I was thinking about using one on my last car, but that would have been a lot more straight forward than on our cars
peace
Cyberpunky
peace
Cyberpunky
The easiest way would be to leave the existing water pump casting in place. Remove the roller, spindle and impeller and tap the spindle hole to fit a regular 944 idle belt roller. Use the same belt and fit the electric pump into the external piping.
The advantages would be:
Less parasitic power loss from driving mechanical water pump.
Less wear on belt from drag caused by water pump roller.
Less expense, no need to change water pump due to wear in water pump roller, just replace the roller.
Plus with an external controller you can more accirately increase/deacrease water flow depending on engine temp.
Keep in mind OEM electric pumps are computer controlled, and without such computer control, they are actually an energy hog, because alternators are less than 30% efficient overall at generating the power needed. Seems like a lot of trouble for something that lasts 100k miles and costs a couple hundred bucks at most.
Rainman
if you fix pump flow to RPM, or just make it run constant RPM at high flow rate it would work for probably 95% of street driving. add a **** or something to kick up the flow on hot days...boom.
Rainman
i cant imagine even a big pump taking that much power to run continuously...besides, bigger alternators are easily adapted (the nissan 130amp for example...) and i could have a twin-alternator setup on my 944 soon to power the laserbeams i call headlights/stereo/flux capacitor
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
How do you control the flow to maintain temperature? The OEM systems I'm familiar with eliminate the thermostat, which is one of electrics' advantages. That's why they use a computer. Warming up from cold is especially important.
Rainman
So, even a big pump doesn't take much power? But eliminating the stock pump is going to make some big difference?! ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
this one is rated 55gpm (3300gph) and draws 11-13 amps. i dont know the specs of the 944 pump but i doubt it flows anywhere near that much water and the cooling system seems to work out just fine (aside from the pulley issue), so the amp draw could be dialed down.
you are reasonable to think a computer control (maybe some type of independent controller is available) would be good. no argument there.
Most if the aftermarket pumps come with or without a controller. You don't need a thermostat so that's another item for the trash bin. The controllers I've seen work on coolant temp, the higher the temp the more flow from the pump. At cold there would be minimum flow though it would flow throughout the system not just the engine.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
944meister i like how you think im all about minimalism
Spencer go for it!
MagK944 Temp control would work just fine
a remote pump will increase the systems volume, also losing the impeller and thermostat would help flow
my 924s was plagued with over heating until i put a wizard rad in it
this would be a great addition to the system
Spencer go for it!
