I have an 83 chassis I'm putting a turbo engine in and plan to race in the future. I'm in central Ohio and would like to compete in NASA, PCA, and SCCA non-spec events.
The car is currently down to the bare frame. I have a good welder and was considering doing some seam welding to increase rigidity and strength. Does anyone have experience with this on a 944? If I'm going to do it, I'd like to while I've got it stripped down before paint.
Will this disqualify me for races such as GTS events? I've looked through the short info on the series but didn't see anything regarding seam welds.
Having an integral roll cage is probably required - and it will certainly stiffen things up a whole lot. Compared to most 80's hatchback sports cars - the 944 has a really nice frame. Its galvanized, its thick gauge metal, and they didn't chince on the number of spot welds. They are nice solid ones. Again - for the street - this car has a really stiff frame compared to most other factory cars I've driven - even modern ones.
Would all depend on what class you plan to run - but yes, seam welding can be illegal. Sometimes even reinforcement of suspension pickup points is not allowed. PCA just approved welded repair of pickup points within the past couple years for stock class cars. SCCA can be real strict on this type of thing, depending on class (although a 944 w/ a 951 engine will have to run in a regional ITE type class, which has pretty open rules).
Do you have the undercoating stripped off the tub? Acid dipped? Otherwise, the seam welding is a big pain. The undercoating and seam sealer are flammable.
Honestly, I think the seam welding done in the 924 build link is excessive. Mostly a waste of time. There may be some benefit around suspension pickup points, but very hard to prove that. Fatigue failures that I have seen on 944 tubs are always cracks near seams, I have never seen the spot welds pull apart. So re-welding the joint will not preclude the flexing of the sheet metal adjacent to the joint - so little increase in stiffness. Only improvement would be to add sheet steel patches to reinforce known/expected failure points; I dont think MIG stitch welds by themselves will help much at all.
Certainly the design and installation of a quality cage is dramatically more important to chassis stiffness than stitch welding over top of spot welded body seams.
I seam welded around my suspension points and a few other spots when building my latest car. It was not acid dipped and I did my best to remove all debris and crap from the joints. Even with a good wire wheel and lots of elbow grease it was tough to get decent welds as there was still crap between the seams (some type of sealer I would guess).
I would definitely check the rules for your class before going forward.
I started w/ a heat gun and a 5/8" wood chisel to scrape the bulk of exposed sealer and undercoating off, then wire whl drill bits and wire brushes and bbq grill brushes. Still would get spatter everywhere, even w/ MIG. No way could it be TIG'd. Would often get smoked out of the shop w/ the crap burning. Might have been a good idea to toast all the seams ahead of time w/ a propane torch, then re-brush it before welding.
In the end, I think it was a waste of time and would not recommend for others to do much of any seam welding, and I will not do it again on any future builds.
I don't know what other cars are built with, but the 944 engine bay frame rails are thinner than 14-gauge steel. With the tube design they are made into they may well be very strong, but I kind of expected them to be thicker...
Thanks for the responses guys. Sounds like it's a no go on the seam welding. The car hasn't been acid dipped, and would be quite the process to remove all the undercoating. Seems like the general consensus is that it won't make much of a difference anyway. I'll put my efforts into a cage.
@V2 - Japanese cars of the era were paper thin, and not as well thought out structurally as the Porsches. I agree though - its no pickup truck or anything!
good luck with the project! Even a rear rollbar stiffens the chassis enough that ive felt a difference, but a full cage is rock solid. Let me know if you need any advuise with the turbo motor swap, ive done a few of these before. BTW_ i showed Dale your website with pics of his old car and he was amazed.
Where were you before painting?? Lol based on the opinions i got here there isn't much for me to gain by doing the welding.
I hope to see you at an event this summer!
I heartily apologize for that. We had some email issues and yours was lost in the shuffle. I did send you my direct phone number should you need to contact me with a little more "rapidity" in the future.
I really hope you can make it out. Lots of new faces in 2012 so it should be a great season!
