Frame reinforcement
Rainman
Anybody got any experience or tips for reinforcing the frame of the car on the underbody? The two rails that run from the engine bay under the floorboard on my car have a few crushed sections from jackstands. There are areas closer towards the front of the car where stands work fine, but further back the metal seems to weaken.
My idea would be to weld a short section of "U" shaped steel to the body over the existing rails to provide a new surface to support the car on.
Thoughts?
Thoughts?
BMW sells metal inserts that you put inside their frame rails if they've become rusted, bent etc. Perhaps you could do something similar to that. Not quite sure how it works though.
Unbannable
The logic of what you are saying is certainly there. This is a pretty common upgrade for Miatas and it made a world of difference on mine. As an example, I had trouble opening/closeing a door with one corner jacked up but as soon as I put the frame rail braces in the doors worked like the car was on level ground. It might potentially help on the 944 although not likely nearly as much as it does on convertibles.
Just as a reference, here is the place I ordered my braces from and I have attached a picture of their earlier braces (without the holes) mounted on the underside.
Edit: Sorry, I misread and thought you meant something for chassis stiffening versus simply reinforcing the frame rails. Oh well, I'll leave my post anyway...
BB.
BB.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
If you do go with U channel stager tacks them,tacks should approx 11/2"- 2" long no more with 1/2" returns at the ends.Also make sure that you remove all the undercoating prior to tacking in the location you tacks weld.After welding zinc coat (spray can) the welds.Then apply a coat of rubberized under coating on your channels.GL
Rainman
the internet always delivers
![](http://carphotos.cardomain.com/ride_images/4/733/1809/39330904005_medium.jpg)
![](http://carphotos.cardomain.com/ride_images/4/733/1809/39330904007_medium.jpg)
this guy had the same issue and just cut and replaced it. it looks like he may have used a factory part though, i would just use a generic piece of steel stock welded over the existing body.
Link to the write-up? Did he replace the existing ones, or just weld a second set on top of them?
I have similar damage on the frame rails of a car, and kept a pair of the rails off a parted/cut up tub to replace them. But just have not got around to doing so yet. Not a minor project, especially if you want it to look good.
The guy Spencer posted cut the spot welds off and replaced the piece. You could go to a sheet metal place and have them bend up a piece like a U with flats at the top for welding in ~16 gauge. .125 may be hard to weld to the sheet metal floor with good penetration without burning a hole in the floor.
I'd also like to see a link to that car. Am I mistaken but is there the start of a tube-frame in the LH rear area and some non-factory metal work front?
![](http://i1196.photobucket.com/albums/aa409/thomakis/d9075ce1.jpg)
this 928 vender sells something that might work http://www.928motorsports.com/parts/...points_944.php
