Help Coilovers hit transaxle oil cooler
Old 01-18-2012, 11:03 PM
johntorg
johntorg's Avatar
Default Help Coilovers hit transaxle oil cooler
I was installing a set of coilovers and discovered that they interfere with the transaxle oil cooler (see pics). I was going to test this car at Roebling on Sat. and now I'm kind of stuck. Anybody have a quick solution. The tubing seems pretty stiff, so I don't think I can bend it. What's involved in removing or bypassing it?
I tried 2 different coilovers, but neither fits.
Old 01-18-2012, 11:15 PM
MAGK944
MAGK944's Avatar
Common problem permanently solved by removing the factory cooler coil and fitting a small aftermarket "radiator style" cooler there instead. Plenty cheap on fleebay or try your local parts store for a small trans cooler. I got lines and adapters also from a local store. GL
Old 01-18-2012, 11:27 PM
johntorg
johntorg's Avatar
I guess that's what I'll do. Not going to be ready by Saturday.
Old 01-18-2012, 11:36 PM
MAGK944
MAGK944's Avatar
John, have you tried mounting those coilovers upside down? It might give you enough clearance to run the stock cooler coils. Only pic I have of mine is the wrong side but you get the drift.
Old 01-18-2012, 11:40 PM
johntorg
johntorg's Avatar
I'll look at inverting them, but I'm pretty sure the spring will still hit.
Old 01-18-2012, 11:42 PM
johntorg
johntorg's Avatar
Your lower bolt looks a lot shorter than mine
Old 01-18-2012, 11:53 PM
MAGK944
MAGK944's Avatar
Different design though I don't think the actual lower mount is positioned any differently. Looks about the same distance from the face of the control arm to the lower mount. Mine are Ground Control I think yours are Racers Edge.
Old 01-19-2012, 12:03 AM
xsboost90
xsboost90's Avatar
i took mine and pulled it off the braket and put it on top of the braket-instead of mounted below- this seemed to make enough clearance.
Old 01-19-2012, 12:07 AM
johntorg
johntorg's Avatar
Its worth a shot. I'll try it tomorrow.
Old 01-19-2012, 12:13 AM
xsboost90
xsboost90's Avatar
only pic i could find. you get the idea
MAGK944
MAGK944's Avatar
This and inverted my do it, let us know how it turns out.
Old 01-19-2012, 12:17 AM
johntorg
johntorg's Avatar
Will do
Old 01-19-2012, 04:00 AM
sdstimson
sdstimson's Avatar
PM sent, but just in case I did what XSboost did, and put a slight bend in the lines, and I was told not to invert them by a Koni rebuilder, but I have talked to someone who had them inverted and was racing with them no problems.
Old 01-19-2012, 09:32 AM
Oddjob
Oddjob's Avatar
Should not run either of those types of shocks (bilstein cup or 8210 koni) inverted. Regardless, won't change the interference problem.
Must be some difference in the cooling coil wraps on diffferent cars/transmissions. I have not had installation interference between the factory cooler and coilovers on my cars. Probably 1/2" gap or more. I do see some bending of the fins where the coil has rubbed on the spring, probably due to a combination of trans mount flex under load and suspension travel during track use.
Old 01-19-2012, 09:36 AM
johntorg
johntorg's Avatar
I won't try inverted, just bending the coil and placing on top of the mount.
Quick Reply: Help Coilovers hit transaxle oil cooler
