Leaking gas tank
Leaking gas tank
Ok,here's the deal. My car is in storage for the winter. This morning I go to the garage and smell gasoline. When looking for the source, I find the gas tank is dripping fuel. How or why I don't know, because the car hasn't been moved since November. So to provide a quick fix, I want to drain the tank (almost full). What is the quickest way to do this? Help!
Fred
Fred
I put some vice grips on the fuel line between the tank and the pump and pulled the line off the pump. The point that line into a large jug and release the clamp.
If you want to go really fast, unscrew the screen filter from the tank, pull it, and lookout... You'll have the tank emptied onto your garage floor in under a minute. Actually, don't do that... It's a bad idea.
That's a lot of gas to drain. Can you get in your trunk and look at the fuel sender on top. There are two lines connected. I bet one of the leaks would be here. Now depending on how full the tank is the fuel may just be expanding with a change of temp. Although i doubt this time of year that will be an issue. Is your garage heated?
The sender can be taken out as well with a pair of large vice grips. Remove it and you will have access to removing some fuel. Or if you are still interested in removing all the gas, go to an auto parts store and get a fuel pump. Cheapest they got. And about 4 feet of fuel lines. And you will need a couple gas cans. Hook up the pump and start removing the gas.
