Picked up an '88, cranks but won't start...
Hi Guys,
Well my search for the S2 cab halted when I got a 911 (so I've been hanging out in that forum). However, I just picked up an '88 944 that I'm eager to get running. The only problem is that it won't start. It turns over/cranks but just doesn't start. Can anyone recommend what to check first, second, third, etc? Car is an auto. Any help is appreciated and I'm glad to join the group again.
Sorry for the noob question, but can you tell me how to check for spark? Where are those sensors?
Thanks for the reminder about his site. I'll be sure to check it again.
Clark's garage shop manual is a good source of information:
http://www.clarks-garage.com/
How do I verify if fuel is making its way to the rail?
How can I verify if the plugs have spark?
For spark, you can get a spark tester...
or at the local parts store. Or you can pull a plug and ground it (lay the thread on the intake manifold) and watch for spark between the arc post and the electrode...
YOU are much better off taking the car to a mechanic. No offense, but that's about as basic as adding air to tires.
My car is cranking but not starting either. What does the bouncing tach signify? cause mine doesnt bounce.
http://www.amazon.com/Lisle-20610-In.../dp/B0002STSC6
Nothing new just yet. I put new plugs in while I was looking around the engine bay. I have to get a new battery and like you my ignition wires broke so I need to order those. Did you get the wires from Lindsey because they're cheaper than pelican? I'm thinking of getting the tune up kit from pelican as well as the speed/reference sensors and DME relay so I at least have those commonly replaced items on hand in case it's one of them but if Lindsey is cheaper then I'll go that route. So that's where I'm at. Hopefully the parts arrive by next weekend and I can update this thread.
In the meantime, I have some stuff that I hope someone can help me with. Please excuse the dirty engine bay, when all is said and done it'll be cleaned up!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
1st, the following wires were cut (PO told me they were exposed so he cut them and didn't know where they went so he left it alone
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
![](http://i787.photobucket.com/albums/yy153/speedracer671/IMG_4928.jpg)
2nd, do I (or should I) replace these things or are they ok to leave alone (at least cover with a shield so it doesn't get wet)?
pass. side
![](http://i787.photobucket.com/albums/yy153/speedracer671/IMG_4930.jpg)
driv. side
![](http://i787.photobucket.com/albums/yy153/speedracer671/IMG_4931.jpg)
3rd, does anything plug into this round plug (about center of picture) and what is it for? Or is it suppose to be like that?
![](http://i787.photobucket.com/albums/yy153/speedracer671/IMG_4932.jpg)
![](http://i787.photobucket.com/albums/yy153/speedracer671/IMG_4933.jpg)
4th, PO said he replaced these things (I forgot the name), can someone tell me what they are?
![](http://i787.photobucket.com/albums/yy153/speedracer671/IMG_4934.jpg)
Thanks again for the help.
