Fuel Gauge Died
Fuel Gauge Died
So my battery was nearly dead and I tried cranking it and when I cranked it, the engine turned over very slowly and the fuel gauge pegged full for a second then stayed at empty. The gauge now doesn't work. Any suggestions?
Today I got
My Custom Title
My Custom Title
Mine reads very spazzy so I just keep track of the miles on my car cause I generally get 250 miles out of each tank
Early N/A right?
I am seeing almost 500 miles per tank in my 88... but my fuel gauge works, and is relatively accurate!
My money for the OP is on either a blown fuse, or... nah its a blown fuse...
Today I got
My Custom Title
My Custom Title
Sorry to bring this thread OT bordin...
go in the hatch and lift up the carpet. remove the fuel pump access plate and remove each wire from the pump/pickup assembly and clean each connector one at a time. ensure both the make and female are corrosion free. often times the connectors will corrode and you will lose the fuel level gauge. i would start there.
Yup, 83. The most gas I've ever put into mine is 13.7 gal, which is at the point of warning light on. That, with my 20 mpg average gets me about 275 miles. Ummm is it just my "teenage driving" getting me that mpg or is that normal?
I fixed it, for now. I had to replace my odometer gear so while I had the cluster out I cleaned the contacts going to the fuel gauge and it works now. Thanks
How long did it take? Is it a late car? Mine are due for a cleaning as the coolant temperature gauge only works if you flick it
Mine is an 86. The first time it may take 20 minutes to take out being careful and taking your time but once you know how it goes together I can do take the cluster out and have the speedo off in maybe 15 minutes.
