Tie Rod question
I have looked at my steering assembly. I know my rack probably leaks or at least the hoses do a bit. My question is about Tie Rods. I know there are inner tie rod and tie rod ends. How can you tell if the ends or the innner tie rods are bad. I noticed when throwing my new wheels on that you can "turn" the wheel a little bit before the steering rack moves. Could that be the innner tie rods?
Generally when tie rod ends are bad, the Boots will be ripped, and the grease will be all over the area..
You can inspect them just by laying on the ground and looking.
Lift up the front end and support with jack stands. With the steering unlocked grab the tire at the 3 and 9 o'clock position and push in and out lightly as if to turn the steering.
There should be no play in the front end, if there is inspect the outer tie rod and knuckle for play between the two...replace if there is play. If there is no play it is likely the inner tie rod.
Do this for both sides.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
It could even be the intermediate shaft. Get Someone to barely turn the steering wheel while you shine a light on the intermediate shaft u-joints. Check to see if the shaft rotates slightly without the wheels moving.
My problem was very similar, but was combined two problems:
A slightly bent front right tie arm combined with worn rubber bushings on the sway bar.
Fortunately, it was easy enough to diagnose once I got under there and noticed the decayed rubber and inability to adjust the wheel alignment.
I have noticed that my shaft is making a popping noise, but how would that affect the tie rods? I can move my wheels just a little bit without it moving the rack? Would that cause be the tie rod end or inner tie rod?
Just saying the issue could be the intermediate shaft and not the tie rods.
