Denver - need help w/ cam tower gasket & aluminum weld.
I need help sometime to replace my cam tower gasket,etc. Can anyone help.
I also need to have a small weld done on my aluminum strut brace. You don't need to be an expert.
sorry CO, too far for me...... have you gotten started yet? If you are only replacing the cam tower gasket and no balance belts or timing belt or seals, , you can do this job in 30 mins if your confident and can turn a wrench without questioning your skill level.
30 minutes? Maybe like, Inception second-level dream minutes.
http://www.944time.com/porsche/944-cam-tower.php
There's a lot to take off and put back on. Just sticking the cam tower on and torquing the bolts is about a 30 minute job.
The 3 bolts back there had loosened up which started the leaking. When I figured it out it was kind of difficult just tightening the bolts. I'm sure I can get them out and back in, but I didn't know if there was anything else involved back there to do the job.
If you still need aluminum welding and you cant find someone to help you out, let me know.
You can mail me the part and I'll do my best to TIG it up for you and make it better than when you got it.
ritzblitz the parts are small enough shipping would be cheap, so that would be great. I thought for sure someone around here would have been able to do it for me, but this works just as well. Thanks!
