View Poll Results: After changing the oil pan gasket, was it leak-free?
Yes, dry as a bone with no leaks!
36
75.00%
No, it still leaked!
12
25.00%
Voters: 48. You may not vote on this poll
Oil Pan Gasket Poll
Old 11-18-2011, 09:36 PM
  #76
mytrplseven
mytrplseven's Avatar
Default back to work
Back to work. After using the dye check, decided to replace every rubber seal I can find. I've pulled the cam tower, intake manifold and found bad vacuum hose, broken plastic vacuum fitting, rebuilt the injectors, prepping and painting the cam tower, intake manifold, cam front housings, replacing all rubber seals , water pump and AOS seals. Engine compartment looks like and IED went off under it as of today.
Old 11-18-2011, 10:21 PM
  #77
Crazy Eddie
Crazy Eddie's Avatar
LOL
I did all of that already and more and now I have to undo 1/2 the freakin' car
Quick Reply: Oil Pan Gasket Poll
