Dash Coming Out Soon - While I'm In There Projects?
As the title says the dash is coming out in a few weeks. What other things should I do while I'm in there?
I have ordered most of the plastic clips that are visible from under the dash, heater, evaporator clips, etc. What about any rubber parts or the a/c expansion valve? This is a FL car so most of the rubber and plastic will be brittle or deteriorated. Any electrical solenoids/wiring under there that I should look out for? Thx
Wait... Instrumentation lighting? -The "dash" doesn't have to come out for that, just the instrument cluster.
In my car, the main air distribution plenum won't send air to the windshield... The dash would have to come out to do that, but since my dash is perfect, and I'm more likely to mess something up, I'm just living life without defrost...
How bad is the insulation likely to look around the heater and evaporator cores? I am dreading that it will crumble to powder. Worth spraying some foam in there?
I'll be checking the air ducts and have duct tape to reattach them to the vents. I think some of them have popped off during the years.
And yeah....it's really likely that you will find all of the insulation crumbled. You don't want to use expanding foam because it hardens. As you drive it will crack (and maybe even squeak/crunch) as components move. Find some high density foam to cut and fit instead.
What about electrical stuff, there seems to be a lot of solenoids, relays, microswitches under there. Should I just buy a bunch and replace - I don't want to get back in there a few months later. Anyone got a list of parts they replaced when they did the dash?
I would seriously consider taking all air distribution hoses out and running them through a dishwasher cycle to get rid of 20+ years of dust, etc. as well as cleaning any areas relating to it, such as the evaporator housing. I need to do this, just haven't put together time and energy for how long the car would be down.
Is there a recommended foam to use or do I just buy any high density foam?
Grounds! Almost forgot, thanks for the reminder. I'm taking the opportunity to also have the windscreen replaced. It has some chips and a small crack. It will be removed and then fitted back after the dash is back in place. So I'll have factory access to everything under the dash
Will post pics and writeup as I'm going along. Just been notified by Rob at 928leathershop that the new dash kit is on it's way!
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
After the dash is pulled you have easy access to the heater flap doors. The doors will have crumbled foam around the edge. I went to Lowe's and bought Felt Door Weather Stripping, cut and shaped it to fit the door flaps for a good seal, "Not too Tight". I added epoxy to the inside edge of the felt as I did not trust the self adhesive to last on the back side of the tape. The rectangular opening for the center air vent also needs weather stripping applied around it. The center dash and both end movable vents have a narrow opening that I filled with a folded thin felt to fit down into and applied regular glue. Now when I close the vents the air is directed where I want it to be. On the Air Handler I replaced all the vacuum lines on the passenger side as these lines actuate the Flap Doors.
http://www.clarks-garage.com/shop-manual/hvac-03.htm
http://www.clarks-garage.com/shop-manual/hvac-01.htm
Cheers,
Larry
Cheers,
Larry
