88 944 na engine
Hello, my timing belt has gone on me >.< my engine vibrates like crazy before it broke. Instead of getting the head and all that done again I am looking for a new engine. My question is am I best going with another 2.5 88 engine or is it possible to get any of the later years with no extra work
Thank you
Thank you
If any one on here has a 88 na let me know near 100k Miles would be amazing closer you are to bc Canada would be easier, I use a freight company with my work so pick up would not be a problem
I'm thinking of if I get the head machined and all that fun stuff again leave the balance belt off turn it over and see how it runs. If I remember right it's over 3k rpm when the balance shaft helps? I may be wrong though
The 88 engine has the only year high compression engine I believe its 10.2:1 instead of 9.5:1. I am not sure about the Canadian models. The DME has a different part number also. If its me, I would do the head again with the help of someone who knows what they are doing especially with the balance shaft belt/pulleys.
I don't see how anything balance belt related can affect timing belt breakage other than the BS belt breaking and jamming pieces into the timing belt, which I have seen a few times.
I had something similar happen, and I had to put a new engine in my 86. The donor motor came from an 87 924s. a few very minor changes to make and it fit right in. Whichever way you go, as long as you scour rennlist and ask questions, you'll be fine.
Good luck, bro. . .keep us posted.
