My Wheel Plan
Hello,
I posted a while back asking about ZR1 wheels, with everyone's help I did a little more research and figured out about what I needed for offset and tire sizes. This is my current setup plan, I would love to hear opinions and know if anyone sees some red flags.
This is on an 86' 951 with an LS1, that's sorta why I want as much rubber as possible without hardcore fender rolling or a WB kit. Some minor rolling as necessary is fine with me.
Front:
255/40R17 Kumho Exsta XS
ZR1 17”x9.5”, 56mm offset, 5x120.65 bolt pattern
Final Offset to be: 35mm
.827”, 21mm spacers needed with a 5x130mm to 5x120.65mm bolt pattern conversion
Rear:
295/35R17 Kumho Exsta XS
ZR1 17”x11”, 50mm offset, 5x120.65 bolt pattern
Final Offset to be: 25mm
.985”, 25mm spacers needed with a 5x130mm to 5x120.65mm bolt pattern conversion
I'm planning to purchase adapters from this company: http://www.motorsport-tech.com/
so what does everyone think?
Front:
Rear:
I think you will need to roll the rear fenders and double check that rear spacer ,with those 11" wheels and 295 tires you can eaasily rub the inner fender.
I have 10.5" x 17 57mm offset with 28mm spacers ,i got half an inch left from the wheel to the inner fender ,check fit with no tires.
hmm, if you're right about your clearances I would be about .4" closer to the inner fender than you. Leaving me about .1" for the rim
since 295mm=11.6" the tire would rub.
Good call, thanks.
Does anyone else have some measurements between rim and inner fender along with their offset numbers? I'd love to measure my own car, but I'm currently in Alabama and my car is in Maine :P
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Good call, thanks.
But, I'm still interested in the option. I just tried looking for the offsets on those wheels and had a surprisingly hard time, what are the 9 and 11" wheel offsets? Also, when you say no adapters you'd still need spacers right? What are the final offsets? Any links to threads with the people running 996 wheels on a 86 951 would be appreciated.
Most of my information was based off this thread:
https://rennlist.com/forums/924-931-...44t-951-a.html
read through it, sounds pretty convincing that what I have listed will fit
It seems like "will these wheels fit", "what size tires can I use", etc etc type threads are one of the most rapent subjects on car forums. Problem is, you turn around and one person says "oh yeah, those'll be fine" and the other guys says "no way". It's one of the most frustrating subjects to get good information on and filter through the billions of opinions, so if anyone has the be all and end all answer please let me know.
So far everyone here has been the most helpful and informative!
I'm sure I'm not the only guy a little bemused by all the information floating around about this. That's just my little rant........
996tt wheels- 18x9/11 - 225 fronts/295 rears. 86 turbo early offset. Used 1/4" spacers up front and on spacer on the rear-dependent on which way your rear suspension is shifted and camber you may or may not need spacers. Close to inner/outer wheel wells w/ rolled fenders. Also ran 525lb coilovers which prob. kept them from rubbing more.
Speedline 18x9/10 - 245 fronts/265 rears. Converted car to late offset- no spacers but w/ 50mm offset needed some camber in rear to clear wheel wells-although the car already had 3.5 rear camber so no issues.
BBS Sport Classic2's -18x8/9.5 late offset n/a fit w/ only front spacers to clear hubs 1/4"
Boxster twists - late offset n/a fit w/ no issues- front spacers? cant remember
Cup 1 replica wheels- heavy- early offset on early offset turbo- rolled rear fenders to keep from rubbing. 17"
Regarding the 996TT wheels; they are very inexpensive and easy to find. You can get the hollow spoke version and end up with a fairly light, OEM wheel setup. As long as you can stand the "twist" styling. Search the classifieds here and at 6speedonline.com. You'd be surprised what little money they bring.
18x11 ET45mm
18x8 ET50mm
Do a search for user xsboost90 (Dan). He's extremely helpful and ran this setup on his '86. He can tell you what spacers to run. Realize that all 944s are somewhat different when it comes to nailing the offset. This is further exacerbated by attempting to adapt the GM wheels - which, to my knowledge, hasn't been done yet.
Not sure I read your plan right, but the adapter alone will act as the spacer. The advantage of using the OEM Porsche 18" wheels, is that you don't need adapters, you will have more tire choices, and slightly nicer look. The difference in ride between the 17" and 18" wheel is negligible, in my opinion. It took some planning and work, but I do like the 295s on my LS swap.
18x11 ET45mm
18x8 ET50mm
So did Danno find some overly optimistic information:
https://rennlist.com/forums/924-931-...t-951-a-2.html
DanD,
I think 3-piece wheels are your only options in the larger sizes. Although there some Porsche wheels in 18x10" (expensive), but you'd have to install longer studs and spacers to use them.
Here's a photo to Doc's wheels:
http://boards.rennlist.com/upload/lance_waiting.jpg
For maximum cornering power and intimidation, you can easily use the following setup on an '86 944/951 (requires 2.5" front coilovers):
front: 17x10" 35mm offset, 255/40-17 tire
rear: 17x11" 25mm offset, 275/40-17 tire
According to TurboTim, you can actually squeeze a 315/35-17 tire in the back with this combo....wow... I'm going to try the 275mm first and measure the clearances.
These are what I have from Ground control http://www.ground-control-store.com/...p/II=77/CA=219, the springs are tiny compared with the stock springs. Once again, I'm away from my car so I can't measure them directly
Beautiful cars btw! Some new posts popped up while I was replying, thanks!
Yeah- I know adapters are also spacers. I wasn't sure if you were saying that you wouldn't even need spacers.
oh- the early offset on the turbo w/ the twists required about a 1" spacer up front. I had bolt on adapters but i eventually installed long studs and pulled the studs from the adapters and made them into slide on spacers. The rear needed 15mm spacers on the ps at first, but after i pulled my rear suspension and pulled the torsions and went full coilover it needed 5mm on each side...since the suspension can slide side to side some.
yuk, I guess I didn't realize that the rear suspension could be so un-symmetrical. What was your limiting factor on the front keeping you to 225's? I'm mostly interested in your 295/225 setup :P
