Drilling Rear Hatch Glass?
I either form, you cannot drill tempered glass. A simple google search will net you lots of results on why you can't
To do what? Look "cool" or be effective. Most effective is in the garage not the car at all. Any other position would increase drag and provide zero down force. on the Cobolt these wings are for looks only.
The only way that would be possible is if the rear hatch isn't tempered..... which I don't know for sure. It might be built like the windshield, and just dual pane glass.
I promise that tempered glass cannot be drilled.... like I said, backed up with 30 years of real world knowledge.
Aerodynamics is something I've been kind of studying recently, just as a hobby. The more you learn about it, the more you learn how much you don't know. Its really not something you can guess at, and get right. That is why every single race car goes through a wind tunnel. Even engineers won't "guess" what might work
If you must attach some dumb looking rear wing please attach to the body or to the hatch frame. Not to the glass.
Attaching to the body will make it hard to access the rear even if you can get the hatch to open and clear the wing. All the 968 stuff attached to the hatch frame not the glass.
Have fun....
I am still palying around with a fiberglass hatch formed like the rear window that I hope to bolt a carbon fiber wing too, (yes for looks sorry guys, but hey just being honest).
If you push forward on this glass idea my advice......
have a shop drill a spare piece of glass from the junk yard if you can find one willing to do the job; then make a aluminum brace for the underside of the glass to spread the stress load from the wing at speed; and anytime you go more than 75 mph pray pray pray.
Don't think it will work, but will be watching.
Good luck.
michael
I imagine, if it can be done, it would be done with either a diamond abrasive bit on a dremel or by a blow torch. Certainly regular glass cutting techniques don't work on tempered glass (as someone said).
Almost Addicted
I'm all for doing whatever you want with your car, whether its a Chevy powerplant or Lexus brakes or whatever, but I'd stick with the factory options or replicas on this one. I didn't care for the 968 RS wing for a long time, but recently it has grown on me. If I need more downforce, that's where I'll go.
xschop normally tempered glasss is "drilled" with a holesaw type device. The most common is a copper drill, almost a tube, and a premixed paste that has carbide suspended in it. The second type is a cabide holesaw that is flooded with coolant as it is cut. Works pretty well and of course there is always risk.
I too have a fair amount of experience with glass, and I can say that I've never heard of a way to drill tempered glass, and have been told repeatedly by seasoned vets that you can't even cut it safely. I also know that cutting or drilling curved glass is nearly impossible (it can be done, but it's super super super hard), so even if it wasn't tempered, it would be very hard to do...
the good news is that glass is a super-cooled liquid, and it flows over time, so eventually your hatch will loose it's temper, and probably be much easier to drill. it'll probably only take a few hundred more years.
are you sure it was drilled. Most cell antenna's back in my install days were an inner and outer piece that bonded to the glass and worked off of induction...
That sounds like a recipe for disaster. I'd want something that was held on by more than the glass if it was actually going to provide an aerodynamic benefit and therefore could get sheared off or rip out the window.
Why not the 968 Turbo RS wing?
