Timing belt
Old 05-10-2011, 09:23 PM
1nice944
1nice944's Avatar
Old 05-10-2011, 09:34 PM
F40LM
F40LM's Avatar
Originally Posted by 1nice944
Just installed my 1985 phone for show....brings me back....$1.50 min. Still lights up.
Love the phone, I remember those, only the coolest people had one.
Nice car dude.
michael
Old 05-10-2011, 09:45 PM
1nice944
1nice944's Avatar
Miss my 1974 260Z
Old 05-10-2011, 10:03 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
I'm sixteen years old, and me and my dad changed my timing belt, water pump on my car with no special tools, and for free (besides the cost of the belt/pump). Didn't even take too long, maybe a week. I'd say save yourself $1300 and do it yourself.
Old 05-10-2011, 10:50 PM
Fintro11
Fintro11's Avatar
using the flip method of tensioning the belts it should only take 8 hours for your first time doing with water pump install your only cost is finding an inexpensive water pump
Old 05-10-2011, 10:57 PM
1nice944
1nice944's Avatar
What if the water pump was new at the time,should I still replace it?
Old 05-10-2011, 11:02 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
New at what time?
Old 05-10-2011, 11:07 PM
pettybird
pettybird's Avatar
not unless it's leaking. it only has 19k miles on it, and not subject to the same rules as the belts.
honestly you'll need some "feel" for the belt or a way of measuring it, but if you have tools to fix a 912 you have the tools to fix a 944. to do JUST belts takes nothing but normal stuff--10, 13,15mm sockets, same in wrenches, a couple others, etc.
Drop the belly pan (10mm bolts)
wind in the alt and A/C adjusters (wrenches)
remove belts
set motor to TDC (24? 27? mm socket for crank pulley nut, socket wrench)
remove airbox if it's in the way (not sure--have a turbo and a 16V car, and both are)
remove the front timing covers (10mm bolts)
check tension of current belts for reference
remove crank pulley if necessary for clearance to remove timing belt
recheck for TDC
loosen tensioning pulleys
remove belts
recheck for TDC
set marks according to the service manuals and about 1000 other sources
tension by the tool or by feel
recheck for TDC
spin the motor around a couple times to ensure you really, really did set everything at TDC
assembly is the reverse of disassembly
Old 05-10-2011, 11:32 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Nicely put, petty bird
Old 05-11-2011, 12:42 AM
1nice944
1nice944's Avatar
Cool thanks a lot......I was all concerned about the p9021 tool,I think I can handle it,Do I need to take the cap and rotor off?
Old 05-11-2011, 12:57 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Yep
Old 05-11-2011, 12:58 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Clarks-garage.com = everything you need to know
Old 05-11-2011, 01:29 AM
1nice944
1nice944's Avatar
If I'm just going to change the 2 belts (balance shaft belt/Timing belt)Is there just two tension screws one for each? Thanks again for all the advice,I will make this happen,Best place to buy the belts and witch ones are the best.
Old 05-11-2011, 02:06 AM
schip43
schip43's Avatar
This is a good site for tools and info.
http://www.arnnworx.com/catalog/
Old 05-11-2011, 09:13 AM
F40LM
F40LM's Avatar
If you decide to go the kevlar belt route:
http://www.rennbay.com/
Good luck and keep us posted.
michael
Quick Reply: Timing belt
