968 Turbo Build
#32
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
csheffield0524@aol.com
Sheffield Race Cars Facebook Page. Become a fan today!
http://www.facebook.com/pages/Sheffi...00411350044603
#33
The cross over pipe is fully tacked together. I still need to add the waste gate, but I am not 100% certain where I want to place it. I have two locations in mind, but want to have the gate in hand before I finalize its location, but either way I plan to route the exhaust off of the gate back into the down pipe.
Next i'm going to work on the down pipe, but I need to order some more material before I can continue.
![](http://inlinethumb50.webshots.com/46769/2002057280103465472S425x425Q85.jpg)
![](http://inlinethumb22.webshots.com/45397/2678120510103465472S425x425Q85.jpg)
![](http://inlinethumb31.webshots.com/46110/2140061850103465472S425x425Q85.jpg)
![](http://inlinethumb53.webshots.com/45812/2126863550103465472S425x425Q85.jpg)
![](http://inlinethumb42.webshots.com/47721/2788371610103465472S425x425Q85.jpg)
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
http://www.facebook.com/pages/Panama...00411350044603
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
#34
After taking a short break from the Porsche, I was finally able to get some parts in to make some forward progress. I spent the past two days completing the hot side.
I had two choices for the wastegate placement, one was similar to the stock location right after the header under the car, but I opted to mount it right before the turbo directly in-line with the flow of the exhaust. I then routed the wastegate exhaust back into the down pipe. I will add a slip joint bellow in between the gate and the down pipe so I don’t have any cracking issues, but it’s going to be two weeks before I can get one, as it is a special order item for that particular size.
The down pipe will mate up with an aftermarket 3.00” exhaust, but I am waiting for a set of drop motor mounts to arrive before I join the two together. The customer is dead set on running the exhaust all the way to the back of the car (not my choice). I am a little concerned with back pressure issues, but I guess we will address that problem later down the road!
Anyway, here are some pics of the progress.
![](http://inlinethumb04.webshots.com/47235/2154457440103465472S425x425Q85.jpg)
![](http://inlinethumb35.webshots.com/45794/2557442670103465472S425x425Q85.jpg)
![](http://inlinethumb14.webshots.com/47629/2473105020103465472S425x425Q85.jpg)
![](http://inlinethumb01.webshots.com/46016/2168301160103465472S425x425Q85.jpg)
![](http://inlinethumb44.webshots.com/48939/2949093210103465472S425x425Q85.jpg)
![](http://inlinethumb37.webshots.com/47524/2932924460103465472S425x425Q85.jpg)
![](http://inlinethumb47.webshots.com/47598/2215944970103465472S425x425Q85.jpg)
![](http://inlinethumb22.webshots.com/46037/2106030250103465472S425x425Q85.jpg)
![](http://inlinethumb16.webshots.com/45071/2511204820103465472S425x425Q85.jpg)
![](http://inlinethumb22.webshots.com/47189/2890351670103465472S425x425Q85.jpg)
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
#36
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
#39
Talent is talent, some people can paint, some can sing and some are masters of fabrication and speed....this is truly a thing of beauty....keep the motor **** and updates coming
#40
A few updates. I haven't spent much time on this project lately as it has not been a pressing issue, but I am going to try and knock it out over the next 2-3 weeks In between some of the other projects.
![](http://inlinethumb34.webshots.com/45985/2814967960103465472S425x425Q85.jpg)
I added a slip joint bellow between the wastegate exhaust pipe and the turbo down pipe to allow for expansion and contraction.
![](http://inlinethumb51.webshots.com/46898/2780942430103465472S425x425Q85.jpg)
![](http://inlinethumb43.webshots.com/26026/2569600850103465472S425x425Q85.jpg)
Radiator and Intercooler mounted.
![](http://inlinethumb25.webshots.com/49432/2436485740103465472S425x425Q85.jpg)
![](http://inlinethumb57.webshots.com/46712/2681322630103465472S425x425Q85.jpg)
![](http://inlinethumb36.webshots.com/47971/2135904770103465472S425x425Q85.jpg)
![](http://inlinethumb52.webshots.com/49267/2083809540103465472S425x425Q85.jpg)
Upper Intercooler Mount.
![](http://inlinethumb35.webshots.com/46498/2326666010103465472S425x425Q85.jpg)
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
#41
How did you decide on the inlet design and the runner length off the ITBs Craig?
#42
For example, if one runner equals 20 square inches, then I would need 40 square inches of volume for each runner. 40 times 4 gives you a plenum volume of 160 square inches.
This was my first attempt at an intake, so I spoke with some more experienced people in regards to plenum volume and design before I fabricated this one. I also had to take into account the area in which it had to fit in and hood clearance.
Regards,
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
#43
Rainman
Basically I took the length of one runner and multiplied by 2. This would be the volume required for one runner. So take that number and multiply by the number of runners (In this instance 4) and that gives you the plenum volume.
#44
I guess we will just have to wait and see of she performs on the dyno.
Craig Sheffield
Sheffield Race Cars
(850) 896 9064
