pos 944 wont start
pos 944 wont start
i accedently hit a huge huge puddle of H20 omw to get sum food.while waiting in the drive thru my car was fine until i drove off and it started to bog and cough and backfire on me.wat can be make the car not start after i hit a huge puddle of H20. so far wat ive done is
1.pulled the AF(air filter)=no water
2.charged battery=13.98V
3.Pulled plugs=orange spark & oil stains in the porcelain.is that ok or just BAD?
4.checked FP(fuel pump)=works
5.checked dme relay=GOOD liek NEW inside and outside
6.checked coil=good 12V
7.messed around with the S/R sensors
8.checked F.I's(injectors)=good
9.scratched my head kicked the bumper and talked smack to the car yelling at it =priceless and dumb
anything iam missing
Rainman
it may sound odd but park it for a few hours and see if drying it out fixes it...
dont ask why, i dont know the answer either. ive found that if i wash down the engine bay and then it doesnt start, a few hours later it just will.
Take a can of WD40 and spray all electrical components that operate the engine. Coil, spk wires, etc. Especially anything that generates/transfers spark. WD displaces water and should help
iam in long beach man btw iam selling my 944 since i leave in 12 days to BCT for the army http://losangeles.craigslist.org/lgb...124258309.html
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
old wiring = old insulation = cracks = water penetration = shorts.
evaporation = no water in cracks = no shorts.
y du yu youse nonstadert spelen jus trin 2 mak mi lyfe defficut r es it kul r sumpin
Im also in socal, redlands specifically....My 84 hit a puddle 2 nights ago....stalled out. The D-Cap was bone dry....I found a good bit of water on the ignition coil itself when I pulled the dustcover. I dried the top off, put the cover back on...and she fired right up.
My cars stalled out a couple of times in the past...always from a hard splash on the right side. Im thinking of sealing my dustcap with some silicone....that seems to be the weakspot on mine.
I dont have a snorkel on my airbox so I dont worry about the other side....but if sucking water in is as easy as splash stalling the coil....Im glad I dont have one.
The stalling my not be related to the puddle, but more to what created the puddle. On these cars, the battery tray has a tendency to rust out. When it rains water will drip from the hole in the battery tray and run down the wiring harness to the computer.
Pull back the passengers side carpet and remove the plywood computer cover. Check for signs of water.
Not my car...just a pic I pulled off the net...
