968 LSD same as 944?
Please find the dims on it because the 944 side plates can be removed & machined for larger O.D. taper bearings (which is what needs to be done to stick in an Audi
V8 Torsen differential)
so here's another question...will an early 944 n/a lsd swap into an 86 951 open diff trans? if so how easy is the job?
edit....just did a little bit of searching...sounds like i'm NOT going to be swapping in the diff, it looks painful!
