no start ...
Old 11-23-2010, 05:00 PM
  #61
MichaelK
MichaelK's Avatar
Isn't the important thing that each cylinder is close to the rest? I thought they should be within a few PSI of each other.
My car has one cylinder that rang up at 130 and the rest were at 170 and I was told that wasn't good. It has run fine since then though.
Old 11-23-2010, 06:07 PM
  #62
roman944
roman944's Avatar
I think Clark's says that cylinders should be within 10% of each other ... or maybe that's what my Haynes manual says ... can't remember now
so, some of my goodies have been shipped already
why are we getting a REALLY strong fuel smell when cranking? car isn't burning fuel up? can my pump be putting out too much fuel?
Old 11-23-2010, 06:32 PM
  #63
roman944
roman944's Avatar
so we tried to start the car with starting fluid
heard a nice explosion, but the car did not start
so I guess all my air-part of equation works, and my car has spark
why still a no start though?
Old 11-23-2010, 06:37 PM
  #64
StoogeMoe
StoogeMoe's Avatar
Roman,
I don't remember you saying you checked spark at each cylinder. I don't think your rotor is turning.
Old 11-23-2010, 06:56 PM
  #65
roman944
roman944's Avatar
Stoogie - its turning, just went out and removed the distributor car - its in the different position from when I set the engine to TDC to check if my timing marks still align
Old 11-23-2010, 07:37 PM
  #66
Mike C.
Mike C.'s Avatar
Mine checks in around 160 psi (early '85)
  #67
rgs944
rgs944's Avatar
You really need to do a compression check at this point on each cylinder. I would not do or order a single thing untill you find out compression at each cylinder. If compression is good then check spark again, if spark is good then go to fuel issues again.
Old 11-23-2010, 07:42 PM
  #68
Mike C.
Mike C.'s Avatar
So you do get brief ignition with ether... I wonder if it's possible the DME is somehow damaged and isn't sending the firing the plug at the right time? A timing light will answer this one. I'll be curious to see if fuel pressure is up to spec. If the spark happens at the right time and you have fuel, the mixture may be too lean (or rich) to burn. Did you pull out a plug after trying to start and was it wet with fuel?
Old 11-23-2010, 07:52 PM
  #69
roman944
roman944's Avatar
Mike - no, did not
going to see if Jim will be able to stop by with his compression tool and help us out with this one
the "bang" we heard indicates that there is spark, right?
maybe there is some kind of a connector or wire that goes to DME or something that got loose or something ... though, how would that work - if I heard the fuel pump come on when I used the Y-connector instead of DME ...
issue could be too much fuel ... cause by what?
Old 11-23-2010, 08:04 PM
  #70
roman944
roman944's Avatar
how about this:
http://www.redlinemotive.com/replace...eregulator.asp
How will I know there is a problem with my fuel pressure regulator?
You will know there is a problem with your fuel pressure regulator from several noticeable symptoms. There will most likely be hesitation during acceleration, excessive load up during deceleration which may cause backfiring or emission odor, and you may even experience a choking sensation like the fuel or air is being completely cut off from the motor at times. Some vehicles may give you a warning light or trouble code to identify the problem.
sounds like the problem my car was having
ALSO, we tried to see how much fuel/how fast it would go from dampener (just like with the fuel rail) - and the glass 850ml cam in at around 25 seconds
Old 11-23-2010, 08:27 PM
  #71
rgs944
rgs944's Avatar
Roman, I just experianced a engine personally that wasa no start that had a weak #1 cylinder. I wish I was there to run the test for you. You been over a lot of things. A compression test is so damn easy and it would tell you if you are wasting your time on a lot of other things. If you have a tester in front of you we are talking about 5 mins to check. You checked spark and timing and both sounded OK, you have been over and over the fuel system with no luck, it is now time to check compression. I do not want to sound like I am preaching but it is needed information and so easy to check.
Old 11-23-2010, 08:40 PM
  #72
roman944
roman944's Avatar
I hear you, and we'll try to get it done ASAP - waiting to hear from Jim, if not that, then I'll ask some other friends and see if I can get the tool form Autozone or something
would rather try to do it right with the tool, no?
Old 11-23-2010, 08:49 PM
  #73
Roger Collins
Roger Collins's Avatar
Don't know if it has come up in this post yet, but check the reference sensors
Old 11-23-2010, 09:09 PM
  #74
roman944
roman944's Avatar
my tach bounces, which supposedly means that my speed/ref sensors are good
still believe my problem is with the fuel/system though
hopefully I'll hear form Jim about the compression test soon, or will just rent one from Autozone and see what happens
Old 11-23-2010, 09:57 PM
  #75
shiners780
shiners780's Avatar
Hey Roman, I'll stop over tomorrow afternoon around 2:00ish. Be sure your battery is charged up, all that cranking is probably running it down.
Quick Reply: no start ...
