porsche gure help!!oil presssure engine light!
Ok is been 3 days of own s2! since I got the car check engine light is been on, dealer check it din't find matter??? can belive it!but have actual paper work!!! I noted this morning at first cranking the car! it took 5 second to get full pressure bars in gauge! ok I drove car to tire shop , drive it back parked and , this afternoon star reading about check engine light and stuff! 9 hours pass then this time I went to put mor attention to the car crank it and in fact 4p 5 second took to oil presure built up, but was just from nothing to full!!!!like that but took 5 seconds!!!! I read in post that someone have same issue and at end was the OPRV MISSING O-RING OR O-RING DESTROY FOR OIL OR SO!!!! Ok so I 99 sure that is my falut problem with OPRV maybe my o-ring is bad or gone? SO wondering part number for oring s2??
washer part number?
if I tasking this tuesday that OPRV can be take apart clean?? or not will be probably just the oriung replace car driving keep full presure when wrn up presurre goes to 4-3bars all time!
ok now let me explain if that OPRV the problem so the engine light is realated to that? If so why doen"t reset it self after engine built up pressure or ones is trigger get record in ecu and will be there??? or engine check light is related to something else like oil level unit? and I will have to check other stuff!! hey Thanks again for anyhelp![/COLOR][/COLOR][/COLOR]
washer part number?
do you ever try to figure out anything for yourself or bother to use the search function...or do you just expect us to tell you how to fix EVERY problem you have with your car? mechanics...those guys can be helpful too...
men sorry to bother you If I asking if beaciuse I don't know!!! I alredy search all day and thansk to taht get to conclusions but I need more support from peopel that knows alot and have been in ownership of this car for longer than my 3 days!!! thanks any help
I believe the ! light is related to oil level. If the seat belt light and the ! light are both on then there is a reset procedure you could try. Go to Clark's Garage and read about the reset.
I think the coming winter is making some people cranky around here.
The "!" can come on for a variety of reasons. It will come on any time another idiot/warning light comes on.
It will also come on (by itself) when there is a trouble code.
I recently had this problem and mine turned out to be a faulty Engine temp sensor....but there are numerous other reasons.
rgs944 __I've been around on Pelican & here for a while now, and usually don't bother replying to this kind of comments since I truly beleive that we are here to help each other since the majority of use has the same goal keeping our P cars alive but__hevquip__is rigth take a look at this guy posting, here & specialy Pelican & then you migth realise why peoples can get very cranky around this person.
you guys need to cool it. your not helping at all. he is a little weird but no need to flame. why dont you just not say anything??
in the past 6 years of working on these cars i noticed the ! light was related to the ebrake switch or a fault in the airbag. have you looked into the ebrake?
Thanks there!!! I posting cause really confuse here!!!! when I first put key position 1 I get all light in dash bord then when I cranks it all then go away actually last one to go away is airbag light it stay for 2 sencond then I got the botton red LETTERS CHECK ENGINE " and is dosen't go !!!! I not sure also about this but the fasten seat belts just come at position one of key with all other lights !! dosen't make difference if I fasten my seat belt or not! like other porsche cars like my boxster S it stay on until you fasten your seat belt in this 944 not! is this normal!!!! I guess i can make video and poste it to get better help that way!! Thanks alot
ok in that post said the check engine light red color is only available in 90 91 s2? is that right and 968?? SO I get kind confuse is related to emisisions> like oxigen sensor?? or knock sensor?? or other? where is location knock sensor to be replace? thanks
