Will a 85.5+ Alternator fit a 85.0?
Cruisin'
Great. They said it was 115 versus 90 at Discount Auto. It's quite the monster size...
Should do good for the 55/100 Hella's, and the Hella rally lites on front :-)
Cheers
Mike
Cheers
Mike
No Mike. Wires are like pipes. If you don't enlarge them, you are screwed, unless you raise voltage or go to superconductors. Not an easy option for us.
You may get a bit more juice down there with the higher voltage, but you are still on the short and crummy end of the stick.
I know you were joking, but I'm getting 3 e-mails a day on jokes.
Regards,
Ice
Regards,
Ice
Cruisin'
Yeah, pully is different I found out last night.. Got the old one off fine, but the new one won't come off! Going to get an impact wrench on it tonight (if I can find a way to hold the fan blades).
Also the mounting bolts are different. The old one has a threaded lower mount (the one that shares with the AC) and the new one doesnt (simple, just get a longer bolt with a nut). The top is the opposite! It used to be bolt/nut but now the alternator is threaded. Ugh.
Mike
Mike
If it even matters, I know that you can adapt a certain Chevrolet altenator to a 944, not sure which one, but it's worth checking into maybe. ALso, alot of times the altenator just needs rebuilt (not hard).
