Ezcarlift
Old 10-04-2010, 11:23 PM
cas951
cas951's Avatar
Default Ezcarlift
Anyone here seen or used this lift before? I've been in search for a small car lift for awhile now and I think I finally found the one that fits perfectly in my two car garage.
http://ezcarlift.com/ezcarlift_video.html watch the video. Interesting.
There's also a group buy I'm considering joining.
I hear the first round they had 60 buyers.
http://www.gotogroupbuy.com/635/Grou...ount-Sale.aspx
Old 10-04-2010, 11:42 PM
Marcquito
No, not Mosquito!
Marcquito's Avatar
Location: Gliese 581g | Monte-Carlo, Côte d’Azur, La Planète Terre
I bet I could kick that over.
Old 10-04-2010, 11:53 PM
cas951
cas951's Avatar
I'm sure with enough effort anyone can.
Old 10-05-2010, 12:05 AM
dykaar
dykaar's Avatar
Seems spensive for what it is. A full blown lift isn't that much more, is it?
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...3&d=1283457963)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Old 10-05-2010, 12:37 AM
cas951
cas951's Avatar
My garage is a regular two car garage. A full size lift takes too much space. I really like the optional wheels where you can move the car around while still on the lift.
I've been debating for the last month whether to buy this or not. Now I see a group buy it's even better.
Old 10-05-2010, 01:21 AM
Darwantae951
Darwantae951's Avatar
For anyone with limited space, the maxjax looks like a viable option.
Old 10-05-2010, 01:25 AM
90Carat
90Carat's Avatar
I can use it as a picnic table?!?!??!
SOLD!
Though, I wish it could handle more weight. This could work for the 944, but not the Yukon.
Old 10-05-2010, 01:29 AM
90Carat
90Carat's Avatar
I don't know about the Maxjax. I see the drop in anchors getting all full of crap when not in use. Though, that might be avoided by using a second second set of flatter head bolts when the jacks are not in use.
Old 10-05-2010, 09:29 AM
Lemming
Lemming's Avatar
I would rather have a bendpac scissors lift that will go to 48" than that thing.
Old 10-05-2010, 09:37 AM
Toran
Toran's Avatar
Man ol man 2K for that!
Old 10-05-2010, 09:59 AM
choinga
choinga's Avatar
I'm installing my new MaxJax today actually - pictures coming...
I intend on just leaving the bolts in when not in use until I can find some kind of plastic or rubber fitting that will work to cover the anchor holes. It's not a big deal...
Old 10-05-2010, 10:59 AM
dykaar
dykaar's Avatar
US$1450 + shipping:
http://www.eagleequip.com/page/EE/PROD/IOS/MTP-9F
113" overall height, but thats just the two posts, so worst case you make cutouts in the ceiling. Its not like you need to modify the porsche...
Regards,
doug
83 944 (sold in 86)
Old 10-05-2010, 04:35 PM
cas951
cas951's Avatar
This is another option but cost a little more.
http://www.gesusa.com/Dannmar-MaxJax...-p/1375659.htm
Old 10-05-2010, 05:08 PM
ZR8ED
ZR8ED's Avatar
Problem with two post lifts is that for "home" use, many garages have uneven (varying thickness of concrete) Many garages are "quickly" poured with NO thought of installing specialized lifting equipment, that requires very specific thickness and quality of concrete. 4 posts though space hogs, are much safer for home use.
Before installing a two post, ensure you KNOW how thick your floor is. Not all floors are created equal. It is a lot of weight to be placed on approximately two square feet of floor. Not just the weight, but the torquing/lever forces of a hoist that is "trying to tip over" (fore/aft) with a 3000lb car 4+ft off the ground.
Be safe guys!
Old 10-05-2010, 07:48 PM
pjburges
pjburges's Avatar
ZR8ED - I've always wondered about this. What if a load spreader plate was used at the base? Say a nice piece of 1/4" steel plate thats like 4ftX4ft? Wonder what the minimum thickness is...
Quick Reply: Ezcarlift
