87 944 NA Strut Replacement, Options?
So I need to replacement the front struts on my car, and I'm wondering what available options I have? I know that the 87 and later are the sealed strut type and I was wondering who all makes a strut insert replacement for this type? I know that Koni has an insert that will work, which requires me to cut open my old strut. Is Koni the only one that does this? I've also heard that I could but strut housings from earlier models and just install new inserts into them and then use them. Is this a possibility? And if so, does any 83-86 strut work? Basically and suggestions would be helpful. I'm trying to avoid just buying a factory replacement strut since those run about $250 apiece.
Captain Obvious
Koni inserts are the way to go, IMO.
Early offset suspension parts will need more updates...should I say, backdates to the rest of your front suspension to make them work.
Your decissions are either:
A) Hacksaw mod your struts (cheapest)
B) Replace the entire strut (best mrodernization of the setup)
C) Buy all the early suspension pieces, backdate your suspension, and then you can buy aftermarket inserts for the early struts that accept inserts... (Just a plain waste of time, money and parts)
+1 on the Koni yellow inserts and If you do not want to do the cutting and stuff Paragon Products has a bolt on option where you trade in your old struts.
I used them and it worked great and I have noticed a huge difference in the cars performance. (no affiliation just a happy customer)
Thanks for the replys everyone. I was planning on going with the Koni hacksaw job, but just wanted to make sure that there wasn't any other available options. Also, I was thinking of replacing my springs while I was at it, and I was wondering if the Weltmeister 220 lb spring would be a good combination with these struts? I was also kicking around the idea of upgrading my stock sway bars to those off of a 951, would this work out to be a good set up for the street? Not planning on doing any kind of track use with the car at this point.
