got the car started ... and it runs!
I looked at Van's video again, and I got my belt to where about he said it should be, or so it seems to me
So we went out and turned it over again, and the timing belt is fine, so we put the rest of little bits and vac hoses on, and got the car started
My battery is completely dead, so we are jumping it.
It starts just a little bit rough but probably because there are a few things disconnected now, but it idles fairly well.
There is a little white hazy smoke coming from around exhaust manifold area, we are thinking that its just some extra stuff that might have drizzled onto it burning off.
There was a decent ticking sound coming from the car when it first started, but that seemed to go away.
I am not getting any belt whines from any of my belts at all. So I think I got the balance shaft done alright.
I need to figure out how tight should my new A/C Delete alternator belt should be, and then I could start the car and let it run/idle.
The carbon canister is also disconnected ATM.
I need to put cooling fans back on, they are connected but not on radiator right now, and I need to secure the clamps on the plastic intake box, and oh, put the timing covers back on.
All in all, not bad!
light smoke = wd40/oil/residual burning off. no biggie. hold the engine at like 4k for minute or so and it'll burn it all off.
noise = lifters repumping with oil.
good jorb!
good jorb!
thanks! yeah its a great feeling ... of relief! LOL
now we are trying to get t he A/C Delete backet alternator belt on, but we can't get it to stay tight
I think there is some kind of a mount underneath the alternator, maybe that is supposed to be secure prior or something
Got the fans on too, so everything appears to be ready. I need to top off the oil level too.
Should I use a 50/50 antifreeze mix or?
Thanks guys!
Thanks guys!
any idea on what to do with the alternator and the belt?
there was this "bar" thing that attached to the engine and A/C but now that the A/C is out, the hole on the bottom of the alternator is much smaller and not threaded
so, this bar needs to be removed? and the alternator just needs to be tightened really hard?
we re-tightened it about 3 times now, and every time we are done and its REALLY tight, after removing the pry-bar, if we push down on the alternator it moves down
fast guys bracket
and its down where a/c used to be
seems like that "bar" (for the lack of better word) - was the part that might have helped keep the tension?
this would probably be just like any other a/c delete bracket, my alternator keeps moving "down" and loosening the tension on the belt
lol
this is the part:
![](http://www.paragon-products.com/v/vspfiles/photos/PP944.126.021.03-2.jpg)
apparently its called "alternator strut" - at least by Paragon
so with A/C delete, am I still supposed to use this thing or not?
kind of fun not to have any instructions around ... search brings up nothing
this is the part:
ok then how do I attach this strut to the alternator? the hole on the alternator is MUCH smaller then on the strut itself
mine has a lot of dirt on it, going to spray some stuff and see if it breaks it loose, hope I don't need a new one
