Antenna Delete Plug.?(86' 944)
Old 08-25-2010 | 04:08 PM
fressssssh's Avatar
fressssssh
Default Antenna Delete Plug.?(86' 944)
I recently took off my antenna and now there's just a hole in my quarter panel where it used to be. /; is there a delete plug for this. Just wondering.
Old 08-25-2010 | 04:17 PM
V2Rocket's Avatar
V2Rocket
Rainman
thats not where the antenna was from the factory so there is no commonly available plug for it.
Old 08-25-2010 | 04:23 PM
fressssssh's Avatar
fressssssh
Where was the antenna originally on the 86' 944.?
Old 08-25-2010 | 04:26 PM
KuHL 951's Avatar
KuHL 951
Hey Man
In the windshield. The 83-85.1 had an electric antenna in the DS front fender well. If yours is in the rear quarter it was done by some previous owner.
Old 08-25-2010 | 04:29 PM
fressssssh's Avatar
fressssssh
Dammit. That means I'll have to make up something to cover it. /;
Old 08-25-2010 | 05:01 PM
Cole's Avatar
Cole
Lowes and Home Depot have an entire selection of plastic hole plugs for around $0.70 each. They will usually look like a factory piece when in the hole.
I used this one as a wiper delete plug on my car. I found a real wiper delete plug at the junk yard later and decided not to use it. The plastic plug looks better and is lighter (FWIW)
Old 08-25-2010 | 05:08 PM
V2Rocket's Avatar
V2Rocket
Rainman
nice idea cole.
if you really wanted you could fiberglass the underside of the hole and use some filler and touchup paint..
Old 08-25-2010 | 05:31 PM
fressssssh's Avatar
fressssssh
I'm not sure what I'll do just yet. The lowes/home depot idea works but its not a circular hole more of an oval... /;
Old 08-25-2010 | 06:01 PM
Cole's Avatar
Cole
.....Guess your only option then is Duct Tape
Old 08-26-2010 | 04:19 PM
manydubs's Avatar
manydubs
Go to your local honda or Acura dealer and ask for a antenna delete plug: Probably cheaper at the honda dealer
The part number for the plug is:
82871-671-000 GROMMET (25MM)
Worked perfectly on my 84 944 when I just installed a hidden antenna instead of the OEM power one which broke...
Old 08-29-2010 | 12:56 AM
JayZzzz4's Avatar
JayZzzz4
My 924S has the antenna on the front fender, it has some sort of plug in it. Sorry, only picture I have of it.
Old 08-29-2010 | 01:22 AM
Marcquito's Avatar
Marcquito
No, not Mosquito!
From: Gliese 581g | Monte-Carlo, Côte d’Azur, La Planète Terre
just fix it - and fix it right.
Old 08-29-2010 | 10:35 AM
krystar's Avatar
krystar
if yer gonna do it half ***, at least do it right. quote by my friend evan. hehe
Quick Reply: Antenna Delete Plug.?(86' 944)
