Re-sealing Injectors, wrong BOSCH kit - WTF!
Old 06-21-2010, 10:12 PM
Mike951
Mike951's Avatar
Default Re-sealing Injectors, wrong BOSCH kit - WTF!
Got BOSCH kit 1 287 010 704 to re seal my injectors ('86 951). A quick search led me to find that apparently this kit does not fit correctly. I then found that Rennbay sells a correct kit (blue caps). Is there another source for the correct kit somewhere near NJ? I really don't want to have to wait all week to get friggin injector seals.
Also, how do the hats comeee off? You just pull them?
Mike
Old 06-21-2010, 10:22 PM
elzergone
elzergone's Avatar
I am pretty sure Kragen/Autozone/Whatever stock seal kits that will fit. A rennlister discovered a while back that the caps and seals for the injectors that go in a ford 2.3 turbo will work. Part number on the cksauto website is 1580079. You may be able to find that locally
Old 06-21-2010, 10:26 PM
elzergone
elzergone's Avatar
Oh right, and taking the caps off.
BE REALLY REALLY REALLY CAREFUL!!
I broke the pintle off of two injectors before I learned. If the old orange injectors are still on there, then carefully squeeze the sides with pliers to crack them off, they should be brittle enough if they are original.
Just dont use pliers to try and pull them straight off. If you can, cut the seal off to give yourself some room around the cap, and use some kind of slotted surface to slide the tip into, and pull on the injector itself to get the cap off.
This is a combination of my own painful learning experience, and JohnKoaWood's advice.
Old 06-21-2010, 10:31 PM
WizPorsche944
WizPorsche944's Avatar
I cannot believe that Bosch never fixed this kit.
Old 06-21-2010, 10:36 PM
PorscheDoc
PorscheDoc's Avatar
Any auto parts store should have the Borg Warner kit (blue caps). Heat the pintle caps up slightly before assembling. The bosch kits suck.
Old 06-21-2010, 10:41 PM
BlackOp
BlackOp's Avatar
I just went through injector hell...one was leaking, so I re-sealed all of them. Another one starting leaking, swapped o-rings/tip (2nd time) then the first started leaking again. Then the third one started and the other two stopped. This was with the blue tip kit. What was strange was when I pulled the leaking ones...each time the new plastic tip was loose. Believe me, I snapped those StrekStrekStrekStrekers on there tight and it still repeated.
I ended up ordering 4 rebuilt ones from pelican...$240. They worked perfect the first go. My car runs awesome now...they made a difference.
I think, now, I could possibly beat PorscheDoc in a fuel rail removal race....ha. Six times a charm.
Old 06-21-2010, 11:08 PM
V2Rocket
Rainman
V2Rocket's Avatar
you can also use the injector seal kit for a ford 2.3 turbo available at any autozone
Old 06-22-2010, 12:05 AM
PorscheDoc
PorscheDoc's Avatar
Haha, lets not get carried away now
Old 06-22-2010, 12:24 AM
BlackOp
BlackOp's Avatar
Yeah....but I shaved 75% off my initial removal time. That has to count for something. Repetition, repetition repetition...repeat. I was stuck in a never-ending, engine fire loop...
Old 06-22-2010, 12:53 AM
Mike951
Mike951's Avatar
What year ford 2.3? Is this a full kit or just the blue hats? It is identical to the Rennbay kit? Do the injector seals fit correctly as well?
Is it super critical to change the hats? Or could I just change the seals and not the hats...I'm afraid I might have issues with the hats. I might try hot-knifing them off....good idea?
-mike
Old 06-22-2010, 01:12 AM
BlackOp
BlackOp's Avatar
In my case...I dont know what happened. I searched every injector thread on this forum. I started to question my manhood, gene pool, and overall self-worth. I mean .... if I cant take off a plastic tip and replace it correctly, this is probably a bad car for me to be owning. I chalked it up to God hating me...
When I got my new injectors...I didnt change anything as far as installation. They just worked...
Old 06-22-2010, 01:17 AM
V2Rocket
Rainman
V2Rocket's Avatar
-mike
the ford thunderbird turbocoupe 2.3L 4 cylinder, 85-88 iirc. plastic washers, o-rings and pintle cap are identical
Old 06-22-2010, 01:24 AM
944old
8th Gear
944old's Avatar
The AC delete pic looks better here than on my phone..
Old 06-22-2010, 01:38 AM
Mike951
Mike951's Avatar
I found 2 kits that are for FORD applications that look identical:
'88 Thunderbird Turbo
http://shop.advanceautoparts.com/web...S_785553195___
'88 Mustang 2.3
http://shop.advanceautoparts.com/web...GRPFUELAMS____
Anyone know what might make these two kits be listed under different part numbers? They look identical...
One is $2.79 and the other $5.99 which is weird other then the fact that one is BorgWarner, the other Beck Arnley
Hopefully one of these works because I can get them locally
_mike
Old 06-22-2010, 02:00 AM
V2Rocket
Rainman
V2Rocket's Avatar
the kit i used was made by niehoff. regardless, make sure its the injectors for the 2.3 turbo. as in, ford thunderbird turbo, mustang svo turbo, merkur xr4ti
Quick Reply: Re-sealing Injectors, wrong BOSCH kit - WTF!
